Battery Shorted and High Current Array Blown
gato
New England
2021 JLUR
I'll take a look at the turbo wastegate, but wouldn't that throw a code also for low boost or no boost? I know there is a boost sensor.
You'd think that it is monitored. There should be an "implausible boost level" or some other code. But if the wastegate is dumping it all overboard, maybe it does not trigger anything. Either way, you have such a massive power loss, that I can't see it being just timing.
cosunrise
cosunrise
Denver, Colorado
2018 Jeep Wrangler Unlimited Rubicon
The Tazer did not recover, but I still have Jscan.
Thanks @gato for pointing me in the turbo direction. Turns out the guy who replaced the turbo🙄 failed to reconnect the boost pipe... Had good intentions of cleaning it and the intake up and getting the oil out from the failed turbo, but you know that they say about excuses.
Anyway, she sails up hills now with more power than I need.
Appreciate all the technical (and moral) support.
ScotM
Scot
Southern California
2022 Jeep Willy's JL 2 Door
That was a lot of work for you. Congratulations on successfully navigating through all those codes and problems. Excellent outcome.
gato
New England
2021 JLUR
Excellent news!!! No better feeling than when it is a simple item that was overlooked and makes all the difference. Sounds like you are close to bringing the Jeep all back to health.
UncleJimmy
AZ
2020 JLUR; 2016 Toyota Tundra
OP when you get a chance, give us a synopsis of what parts you had to replace and which ones didn't work or weren't necessary. Thanks.
