Battery issues while towing
tsitzmann
Arizona
2018 Wrangler Unlimited
New to the forum and NOT mechanically inclined. I've been towing a 2018 Wrangler Unlimited (Rubicon) for 5 years, first behind a 2019 OMNI and now a 2019 Dutch Star. When I reach my destination after 6-7 hrs, it's hit or miss if the jeep will start. I've replaced the main battery three times and the aux battery once, but the problem persists. On a whim, I disconnected the battery but was able to start the Jeep. Didn't know you could do that. Anyone have any ideas on what I am missing?
AndySpill
Andy
Pittsburgh
2018 JL Sahara
https://www.jlwranglerforums.com/forum/threads/jlur-battery-flatlining-when-flat-towing.15523/
Occam'sRazor
New Mexico
2018 Mojito JLUR, 2023 Reign JLUXR, 2023 Earl JL
Is anything in your towing set up charging your battery?, if not then that is probably your issue, especially if you have LED taillights from the factory. Every time you brake it wakes up your computers and starts a power drain. Cool Tech LLC has a solution to stop the wake up but if you are not mechanically inclined I wouldn't advise it. A charging solution will probably solve the issue. Your motorhome should be charging the Jeeps batteries while you drive through the umbilical.
Yes you should read the thread just posted.
tsitzmann
Arizona
Occam'sRazor
New Mexico
