Ball joints factory torque specs
Space ace
2018 Jeep Rubicon
Does anyone know the torque specs on the JL ball joints? My service department says it’s 33 foot pounds.. but I thought I read it was higher..
thanks..
WXman
Central Kentucky
2018 Wrangler Unlimited
15 ft/lbs??
That's funny because if that's true, it explains why there are posts floating around about the ball joints being "loose" on the JL Wrangler. :cwl: You can tighten 15 ft/lbs with a tiny 1/4" drive ratchet. Doesn't take much torque.
JIMBOX
JAMES
FERNLEY NV
RETIRED
Yeah, I rechecked the lower Ball at 15 lbft is INITIAL, then 33lbft FINAL where the vehicle weight is most supported and the NUT is just to make sure it doesn't fall out, the top Ball is for preset CAMBER and supports the vehicles CASTER in all steering angles, so 55lbft--(caster is SET/w the front UCAs/LCAs)
It's a jungle out there-
W.E.
JIMBO
Wfd1244
Shawn
Wichita Kansas
2018 JL wrangler unlimited sport s
I had my ball joints replaced by the dealer after I had the clicking noise problem. This was the sheet that came in the box with the ball joints explaining the installation.
Top ball joint: 52-59 ft. Lbs.
Bottoms ball joint: 30-37 ft. Lbs.
ocrejects
Orange County, CA
2021 Rubicon, 2018 JLU Rubicon, 2018 Tiguan SE
Was that a 2018 JLUR?
Devan003
Don
JLU Rubicon
I have taken my jeep to the dealer 3 times for the clicking noise. just picked it up and they changed the front spring isolator.
I told the service rep to check the ball joints. They don't listen. Help me out JEEP! There should be a TSB for this.
@JeepCares
JIMBOX
JAMES
FERNLEY NV
RETIRED
Lower Ball Joint--33ftlbs--
Upper Ball Joint--55 ftlbs--
Good luck
JIMBO
JeepCares
Auburn Hills, MI
JL
@JeepCares
Hi Devan003,
We are sorry to hear about your frustration. If you would like to have a case escalated to add additional assistance throughout this process, please send our team a private message!
Alex
Jeep Social Care Specialist
unsavory
Jimmy
2022 JLUR XR 2.0T Auto, 2019 JLUR V6 Manual (sold)
So I have been dealing with a clicking front end as well, and I have a theory as to the problem.
The instructions posted here by Wfd1244 specify that you should first torque the ball joint, and then continue past that point to the next available slot for the cotter pin. But I have a feeling that they are being torqued to the specified torque value, and then if the hole is already lined up, they are being left in this position.
Well the problem is that if that nut backs off even a tiny amount from that point, which it can still do with that cotter pin in place, then the nut is only practically finger tight at that point.
The reason I know this, is because I already checked my ball joints once, and I did exactly this, and the clicking was still present. Then after a few weeks, I decided to recheck them, and one of them was super loose.
So this past time, I decided to proceed to the next slot on the nut, even if the hole was already lined up with the specified torque. By the way, while doing this, I heard the clicking noise from one of the ball joints. By the time the next slot in the nut was reached, my torque wrench was clicking over 90 ft lbs. on the top ball joint.
By the way, my front end clicking is now gone.
This would also explain why some people have the issue come back after the dealer "tightens" the ball joint. Because if they don't continue past the torque value to the next slot, it can still back off enough to be too loose.
Just a theory.
kobejo34
Stephen
Hoschton, Ga
19 JLUR
Just a theory.
I like it. Do I need to take the wheel off to do this or did you simply full turn to the right and then to the left.
unsavory
Jimmy
It can be done with the wheel on. You might need to rotate the tire forward/backward to get an opening large enough in the u-joints to get your torque wrench in there.
Fitzz47
Delaware
2018 unlimited Sahara jl
@JeepCares
I feel your pain with the dealer. I took it in to my tire place and explained it to him. He retorqued the nuts and now no clicking.
