Balancing XR wheels
wchevron
RI
2021 JT, 2020 JLU
Just purchased some XR wheels. Was going to take the trim rings off before getting them mounted so the rings don't get scratched. Do I need to have the shop re-install the rings before they balance or can I have them balanced and put the rings back on when I get home?
6th Floor Mule
Keith
Woodstock, GA
2018 JLU Sahara 6MT
Discount Tire needed the rings removed in order to mount the tires. It wasn’t related to potential damage as much as the physical limitations of the mounting equipment. I just removed the rings myself and reinstalled them when I got home. In my experience, no issues balancing without the rings installed.
wchevron
wchevron
RI
2021 JT, 2020 JLU
Thanks
jaymz
Jay
Inland Empire
2018 Rubicon Unlimited
They don't need to be installed, but you can potentially have an imbalance if you install them after.
wchevron
wchevron
RI
2021 JT, 2020 JLU
I think I'll pull them off then ask the shop their thoughts.
2nd 392
Ca
D Tire installed 35/12.50’s yesterday and they R&R’d the rings, must be shop dependent ??‍♂ Early non XR 392- 4.56’s Monday ?
6th Floor Mule
Keith
Woodstock, GA
2018 JLU Sahara 6MT
Yes, DT will remove and replace the rings. I just chose to do it myself ahead of time to eliminate opportunities for them to screw something up while R&R’ing 125 bolts (e.g., over torquing, stripping threads, etc.). Same reason I remove my 3rd brake light myself as well. I just wanted to point out the rings will need to be removed before they’ll mount the tires.
Those 4.56’s gonna get that “kick in the pants” feeling back! Good luck with the installation!
2nd 392
Ca
I let them do it out of “balance” concerns, Also, I just noticed the spare doesn’t have any weights, will be addressed!! Butt dyno tells me I lost half a step, hopefully will gain a full step and be ahead ? Edit- removed the stock 3’rd brake light for Quadratec P&P ring, looks much better IMO.
