islandtees
Anyone using them. What are you're thoughts. I wonder if they really work.
If you believe what you read, there are benefits to using beads. They dynamically balance the tires, so when there is only 50% tread left and the tire has a slightly different weight distribution they will always perfectly balance the wheel, which should make the tires last as long as possible. Also since they are used in place of traditional wheel weights you don't have unsightly weights stuck to or crimped onto your wheels.Not really necessary for normal wheels - I have read that they can help supplement regular wheel weights on beadlocks, as those can be a bit finicky to balance.
But if you aren't running beadlocks - there is no real benefit to using beads.
I do however use them in my motorcycle tires and they work great in that small application.
Never had any luck with balance beads - there is no definitive way to tell if you are balanced other than drivingSo i put them in my tires this past weekend with no luck still unbalanced hops at 45-55mph
