Balancing beads
True Grit
Dale
Houston
2018 Jeep JLU
Do balancing beads work for 40 inch m/t tires ?
Pareto Offroad
Brandon
Durango, CO
2020 JLUR
Makin’ sawdust
I've got ~20k miles with beads and had nothing but problems. 300-400k with traditional balancing and no balance related issues. All 33"+. I don't think they'd be out there if not successful for some people, but I am certainly not one of them.
TJDave
Eastern WA
2018 JLUR Rubicon
Motorized toy collector
Had them for awhile on my old TJ on 35's. I forgot what brand. I was surprised how tiny the beads were. I had problems with them when airing down. I think the tiny beads were getting stuck in the valve stem. I use an ARB EZ Deflater that removes the air valve. I went back to weights and never had another problem. As far as balancing, not that great either.
Lager
MD
2021 JLU Rubicon Diesel
I used them with 33's on my old TJ and they really worked well. That Jeep rolled so nice after installing them. The TJ would sometimes get DW and the beads helped a lot. Perhaps well balanced tires can help prevent it from getting started.
Haven't tried them on my JLU but I plan to when I upgrade the tires. I don't see why they wouldn't work for 40's, they're used on big rig trucks. Just have to add more beads for bigger tires to compensate for a larger possible imbalance.
wibornz
Ted
lansing, Mi.
www.instagram.com
JL Unlimited Rubicon
I have had good luck with balancing beads in my 37s. The sticking of beads in the valve stems means that you do not use the correct valve stem cores. They are different than the stock kind.
I run 14 oz of beads in each tire.
73TAWM
Troy
Missouri
21 JLU RUBICON 2.0T 3"LIFT 37's
Lumber Sales
Surely they're better than the peel and stick they use today. I drive away and they fall off.
