Backup camera stayed on while in Drive
GaryA
Gary
Dracut, MA
2020 Jeep Wrangler Unlimited Rubicon
All, I have a 2020 Rubicon Unlimited and recently had the Uconnect system update. All was working as expected however while driving home recently, the backup camera screen remained on and I couldn't clear it. In traffic, I put the vehicle in Park, turned off engine, started up again, and same thing happened all the way home. It was quite the sight on the screen especially when other vehicles approached.
Today, not knowing what to expect, all working as usual.
Anyone know 1) what happened and 2) how to fix if it does so again?
Thank you
jludave
The Isle of Long
IT Manager
Typical Uconnect issue. If it's working now, leave it. If it happens again and you can't get it fixed, pull the fuse for the radio.
MikeJLURubi
Chillicothe, Ohio
2018 Jeep Wrangler JLU Rubicon
Medicolegal Death Investigator
I've had that happen a couple times but there was an X in the upper right corner than turned it off.
KrzybonesJLU
Vince
CA, Orange County
2019 JLU SPORT S, 2024 WILLY's
There’s an rear camera app on the 7” and 8” screens that allows You to access it. like the last post says there’s an “X” on the corner to close out of it.
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
Thank you
@GaryA
Do you by chance, have a Tazer JL programmer installed on your JL?
GaryA
GaryA
Gary
Dracut, MA
I’ve looked and there was no X, thanks anyway
MikeJLURubi
Chillicothe, Ohio
I’ve the 6.4 inch and there was no X, thanks anyway
Mine is the 8.4 but not without it's issues. My Nav isn't working, bad aircard. Dealer is replacing, waiting on a new radio.
Hope your issue doesn't go that far.
sf5211
Bronx N.Y.
New 2019 JL
Plumber
Drive home in reverse.
Just kidding Gary. If the fuse pull doesn’t do it then it’s probably dealer time.
Dave928
Washington
2020 JLU Rubicon, 03 Silverado, 88 Porsche 928 S4
Aircraft Tech
mine does it once in a while when i hit the MUTE button.
four low
central New York
2018 JL
Isn't there a Setting for rear camera coming on, and a delay to keep it on ? I have this in my Sport, 2018, 5" screen, and find it very useful. Check Settings in case it was accessed ?
Bubsjeep
Bub
Michigan
Rubicon
I just had this happen to my 2021 rubicon. there was no X when this happened like it has if you turn the backup cam on to turn it off. Also no sound from the radio. turned the jeep off had to let it sit for about 5 min. ben ok since.
Wobelnik
Jorge
Tampa Florida
2018 Wrangler Rubicon New Unlimited JL Sport
Isn't there a TSB regarding a software update? That might work.
