Axel alignment affect on tire wire?
Reece
Reece
Houston
2021 Wrangler Unlimited Sahara Altitude
After I installed the 2 inch Mopar suspension live the local shop I went to that my axles are out of alignment affecting my tire poke on either side and need rear and front adjustable track bars. I don’t disagree with this but I want to know how long I can go without installing the track bars until it negatively affects the wear on my new 35 inch tires?
kah.mun.rah
Merenkahre Jr.
Duat
Not rotating your tires regularly or using the right PSI will probably cause more wear to your tires than your axle being shifted over 1/2" from the Mopar lift. That said, investing in adjustable HD track bars have more benefits than just centering the axle so putting them on your to-do list is a good thing but not something I would consider critical.
Fyi, for the rear you can probably get away with just using a track bar bracket instead of replacing the rear track bar.
