Auxiliary Vs Main Battery issue - Puzzled
Brownpow121
Aaron
2021 JLU Altitude Sport V6
Hi all. I have a 2021 JL, 20k miles. Bought brand new in 2021. Noticed the last few days the start/stop wasn’t working. Then this morning after sitting for a day it had a weak start. Then battery totally dead in a parking lot but still lights and radio. Just clicked when I hit the start button. Jumped it, threw a new battery in, fired right up and now the check engine light is on.
my confusion lies in
1. Should I go back in and change out the auxiliary battery too?
2. Why is the check engine light now staying on?
3.Do these two work in sync?
4. Is there any harm in driving it like this u til I get the new auxiliary battery?
I am surprised that this already needs replaced. Looking to lear a bit here and get this solved thanks!
HK1s
Canada, Montréal, QC
23 2dr sport 3.6etorq AT
1. your new battery will die quickly if you do not change in pairs.
2. startup aux battery test fails since it is still dead, or could be some saved error code.
3. they are simply connected, a dead aux will drain and kill a new main battery.
4. yes there is harm
but for now pull fuse 42 to turn off aux battery check, disconnect and wrap the thinner cable from negative terminal of the main battery to isolate the aux. band aid solution until you replace the aux or you can just drive like this without start/stop.
Brownpow121
Brownpow121
Aaron
Thanks all. Going to drive the wife’s Lexus until I get the Aux to replace. Appreciate it
tomk62
Tom
South Carolina
2024 JLU Sahara Anvil, 2019 Cherokee
Common issue. Replace both batteries (or aux delete) as referenced in many other threads, and replace your main with a stronger battery ...
Terrymo
Terry
2023 JLURXR 3.6 ET
There are some great sticky threads in the Battery Talk subforum.
Leisure Freak
Tommy
Castle Rock, Colorado
2019 JL 2dr Sport, 1981 Toyota SR5 Convertible PU, 2002 ChevTracker, 2015 Impala
When I changed my battery the simple loss of power caused it to throw a non related code and the check engine light for Evap. It cleared after a couple hundred miles and multiple starting cycles. I was told by Jeep that it was common for the computer to land on weird codes whenever power is lost and you could be dealing with that. I do agree that if you change one battery, you should change both or bypass the aux battery altogether. I chose to pull the F42 fuse and aux ground cable to run only on the main battery. I never use the auto stop/start.
Brownpow121
Brownpow121
Aaron
I just went to replace my auxiliary battery (underneath my main battery) but there is no battery there.. am I going nuts?
Jeep Wrangler JL Auxiliary Vs Main Battery issue - Puzzled IMG_5749
Brownpow121
Brownpow121
Aaron
I am reading some other threads and they are saying the eTorque engine doesn’t have an auxiliary battery? I have the eTorque.
my check engine light is still on even with the new battery though. Welcome any thoughts. Thanks
Jay Gatsby
2020 JT
You have a 48v battery pack mid truck underneath. What DTC is it?
Brownpow121
Brownpow121
Aaron
DTC?
engine light is off now and start/stop working normal.
HK1s
DTC?
lol... you started by asking about auxiliary, pretty confusing
to identify etorque look for 3 separate coolant tanks on the right of the engine bay and no alternator, as the 12v battery is charged by the 48v system. in your case all electricity the etorque MGU generated went to the dying 12v battery so your 48v battery pack is also empty so start/stop don't work. the 48v battery is lithium no need to worry about that.
but the jeep starts on a conventional starter running on 12v for cold weather performance, hence the weak start and eventually unable to start.
rfg9585
Randy
China Grove, NC
2021 JLU Rubicon, 2020 Sahara JLU
retired
my wifes jeep is behaving similar. cant get the battery to chg and start up. I went to pull F42 but it does not have an f42 fuse. do i just replace the main battery and not be concerned with the aux battery? 2020 jlu shara 2.0.
Ormond Beach, Florida
Retired at 55 ..
Undoubtedly your JL is an etorque JL...
It has a Main battery and no Aux battery and your JL will not have an F42 fuse.
Install a new H7 battery and you will remedy the issue probably..
Read here: https://www.jlwranglerforums.com/forum/threads/aux-battery-how-do-i-know.120115/post-2501518
and read here:
https://www.jlwranglerforums.com/forum/threads/??-main-battery-replacement-talk-jl-jt-?.100534/
Terrymo
Terry
2023 JLURXR 3.6 ET
You can easily tell if you have the 48 volt etorque battery. It will be here. About the size of a small suitcase.
Jeep Wrangler JL Auxiliary Vs Main Battery issue - Puzzled IMG_0972
