Aux Switch Question
crothrock2000
Northern Virginia
2018 Jeep JL Sahara
Hey guys so I just had the Aux Switch installed by the dealership and I got it home and only Aux 3 button lights up when pressed. The others don't light up. So my question - is this normal? Does something need to be connected or configured in Uconnect Settings spot? Strange that one lights up but the other 3 do not. Any insight would be appreciated. Thanks, Chris
Ormond Beach, Florida
Retired at 55 ..
@crothrock2000
All 4 will light up whether you have an accessory attached to the Aux or not.
Even if the JL has not had the flash that turns on Aux, the lights will still light up if the install is aok.
JIMBOX
JAMES
FERNLEY NV
RETIRED
That's right I just went out to my JLR and put the IGN on "RUN" and tried all 4 AUX buttons--nothing
They worked fine two weeks ago and I used AUX#2 FOR MY REAR LIGHTS--WORKED FINE--NOW NOTHING-
I don't know much about the system, or what RELAY provides power to the AUX panel--
Any of you guys done any trouble shooting on this system--do you have any ideas/advice--???
I'd appreciate some fuse/relay numbers--I know F72 is OK-
Thanx
JIMBO
Retired at 55 ..
@JIMBOX
In regard to Aux ....PDC has "HD ACCY" you will find relays 1, 2, 3, & 4, including K17, 18, 20 and 21.
JIMBOX
JAMES
FERNLEY NV
RETIRED
Thanx for the quick reply--I've got all that info, but-
I'm not getting ANY POWER TO THE COMPLETE SYSTEM--I think a relay must have BLOWN and I don't know the relays involved with MAIN AUX SWITCH SYSTEM-
Everything else in the jeep operates perfect, all lights acc.--etc--EXCEPT THE AUX PANEL--
BUMMER
JIMBO
Retired at 55 ..
@JIMBOX
Was your Aux a factory install or done after you got your JL?
If all four Aux suddenly went out... no Aux button lights, l'd suspect the ground for Aux has been lost. If proper ground is lost, then you would see what you are seeing.
By the way.... Ignition can be off and each Aux button still will light when pushed.
JIMBOX
JAMES
FERNLEY NV
RETIRED
The JLR came with it standard and it worked fine the last time I used the rear lights--
That's good trouble shooting --lost main ground !!
Would you have any idea where the HELL THAT MIGHT BE ??
You think it could be one of those main ground posts next to the battery-??
I don't know how that could have happened, although there are a lot of things like that happen to these new JL's-
Thanx RHINEBECK01-
JIMBO
JIMBOX
JAMES
FERNLEY NV
RETIRED
I watched a "youtube" video on installing the MOPAR aux switch option and-
I noticed a small power module they show --
That's the problem--I gotta take time and find it--
Yeah, I know, I could take it to DEALER(WARRANTY), BUT --I'll try to fix it myself-FIRST !
JIMBO
JIMBOX
JAMES
FERNLEY NV
RETIRED
Go to youtube videos and type in--JL JEEP AUX SWITCH INSTALL--
That'll get you in the right video displays !
Good luck
JIMBO
That's great. Let us know how it goes. Can you post the link to the youtube? Thanks!
