Aux Switch Low Voltage Cut Off
fdFifty
Pittsburgh
2022 Jeep Wrangler Rubicon
Does anyone know if the aux switches have any kind of low voltage cut off for outputs configured for battery power?
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
I accidently left our Dometic fridge running in our last JLUR for a few days. It was turned off when I got back in four or five days later. It seems to have protection. The fridge unfortunately doesn't.
fdFifty
fdFifty
Pittsburgh
Interesting. Did the engine turn over ok after?
Fudster
Elliot
Athens, GA
2019 Sahara
My experience has been that the appliances which draw (e.g. Dometic refrigerator) are the things that tend to have such cutoffs.
That said, product like this https://www.amazon.com/Battery-Protection-Undervoltage-Controller-Under-Voltage/dp/B07H4T3LS7 of the Genesis battery system https://www.genesisoffroad.com/jl-dual-battery-kit can address this too.
fdFifty
fdFifty
Pittsburgh
Yeah my dometic and a few other high amperage draw items have some cutoff protection built in. I tend to run these things from a separate power source (goal zero in my case) and then just charge that via switched power while the engine is running.
But I have some low draw rock/ scene lighting I’d like to periodically run if I’m setting up camp or doing other work at night without idling the engine the whole time.
Not super worried since it’s low draw. I just don’t want to get stuck somewhere because the battery happened to be on its way out and I left the lights on for 15 mins. In my experience these JL’s can often be pain to jump start and not give a ton of warning if the battery isn’t healthy.
BullMoose1776
Bull
South Texas
Project Manager
I think you are asking if the switches are unavailable in a low battery state. If that is your question, my experience is yes, the aux switches are unavailable in a low battery state.
When my batteries were going on their way out of commission, I'd start the Jeep and the Aux buttons were unavailable until the battery amperage was high enough.
Lo Tek
40 miles S. of Nowhere, OK
2020 Gladiator JT Sport S Max Tow
OK, necrothread but ... does anyone know if the "Battery" 10A circuit in the passenger footwell has any low voltage protection? Is it powered by the "main" or "aux" battery, or both, or does it matter? As others have mentioned I have some low current equipment I'd like to stay powered without the engine running, but I'd be unhappy to come back to a vehicle that wouldn't start.
