Autostop Eliminator died
Jake21
JJ
San Diego
2019 JL Rubi
Anyone else have their auto stop Eliminator die? Mine is about 6 months old and stopped working.
TIA
JJ
VKSheridan
Vince
Broken Arrow, OK
2020 2 Dr Rubicon JL Hardtop
Mine gets “forgetful” occasionally and thinks I last asked for ESS to be on but I think it’s more of a CANBUS issue then the actual device. I’ll swap out my terminal strip once it annoys me enough…..
Cips
Anthony
Bucks County PA
2021 Wrangler Unlimited Willys
Sales
I use a different programmer to keep my ESS off and occasionally it forgets it as well.
NWJeepr
Twin Peaks
2025 Wrangler 2-door
It was probably a death ray sent by the EPA to burn it up (sent through UConnect, of course).
Keep us posted...will be curious to see if they just send you a new one under the product warranty.
rsmith56
Roland
Western Texas Panhandle
2024 Wrangler Rubicon Unlimited
Have had Autostop Eliminatiors in several vehicles. (Tazer on the Jeep) I just traded my 21 Aviator for a 25. 4 years with no problems. On the 25, is took a different one.
Now have one for 21-24 Aviator if anyone needs one.
fastcar4re
Houston, TX
2018 JL Jeep Wrangler Rubicon
This is what TRL Automotive (the manufacturer of the Autostop Eliminator) told me, and it worked on my 2018 Rubicon when my Autostop Eliminator stopped working after 6+ months or so:
"Try resetting the network by disconnecting the negative battery terminal (the black one) for 5 minutes. If you have an auxiliary battery, disconnect that too. It's more likely it's a congested network than a device failure, but let's see."
DaltonGang
Doesn't Play Well With Others
TIA
JJ
Careful, the Eco Police are lurking. You might be getting a knock on you door, from long haired hippy types, smelling of Patchouli, demanding you hand over that Start/Stop Eliminator.
