Audio Experts-Help Needed Mounting Sub
ChattVol
Tennessee
JLU 4 door
Mods please dont move this thread. I posted this scenario in the Technical Section under Uconnect/Audio in thread "Upgrading non Alpine radio" and havent been able to solve my JLUS sub mounting challenge. I hope this gets more views and a solution.
Secenario: I bought a 8" jl audio
ACP108LG-W3v3 with built in amp and asked my installer to duplicate @cmb396 awesome tailgate mount shown below using the 6 screw holes already on the tailgate with the goal of taking up less trunk space like this:
Jeep Wrangler JL Audio Experts-Help Needed Mounting Sub ehzTnva
He took the plastic off the tailgate and said 6 mounting holes are spaced wide and the lower holes are recessed back atleast 1" requiring spacers to flush mount with the other holes. He could only access getting 2 bolts into screw holes working around the internal box frame/amp through the 8" hole cut out for the sub and didnt feel it would be a good long term anchor considering the box is made of 1/2" MDF. He also thought running large sub wiring through through a hinged area via the black sleave going to tailgate isnt ideal because of the bending of the wires every time the tailgate is opened. He said adding a mounting board would work, but that may block the whole plastic piece from connecting back to the tailgate exposing everything around the sub.(dont want that) @Sting_NC_USA was kind enough to draw this up below showing how metal or plywood mounting board could work:
Jeep Wrangler JL Audio Experts-Help Needed Mounting Sub pG0Z1EZ
Jeep Wrangler JL Audio Experts-Help Needed Mounting Sub HXhxKlW
I am having him lay the sub in the floor until I can get a solution. Any other ideas of different locations to mount this? The tailgate mount is also going to cost more bc he needs to add wiring to reach. I would actually prefer to mount it myself using the current wiring to save money. Here's the current location and I have about 3' of loose wire length left to move it.
Currently sitting here:
Jeep Wrangler JL Audio Experts-Help Needed Mounting Sub guq5rfg
Thanks alot for any help!
ChattVol
ChattVol
Tennessee
JLU 4 door
I ended up building a mounting board on the side of trunk with a 2x6 and mounting there. I gave up on the tailgate mount due to not wanting to pay another $200 for wire + professional install. It sounds great with no vibrations. Looks like this:
Jeep Wrangler JL Audio Experts-Help Needed Mounting Sub skgRG3U
Purity’sPa
Brice
Houston TX
JLUR
Jeep Wrangler JL Audio Experts-Help Needed Mounting Sub 49465EBC-8D7D-4C48-9E89-93F9BE4A9A43
Jeep Wrangler JL Audio Experts-Help Needed Mounting Sub E1DEBAE6-3067-4681-BC5F-339CBA1AD1FF
Here is what my shop did for a 10” JL Audio
Amp rack where the factory sub was and a new Sun enclosure on the drivers side. There is a 750x1 and a 150x4 Marine Grade JL Audio amp
Behind the panel.
Maui-1
Tom
Maui
2018 Rubicon JLU
Behind the panel.
Thats nice! Do the freedom tops still fit in the bag across the back seat?
BlairF
Blair
Humble, TX
2018 JLUS-S Mojito! - 2014 Challenger RT Classic (SuperCharged) - 2016 Dodge Durango RT
Technology Incident Management
Behind the panel.
Who did the work? and guessing that would NOT work with a Tuffy security deck.
Purity’sPa
Brice
Houston TX
JLUR
I always stack the Freedom tops on top mid one another in the cargo area. I never use the case. I’m not really concerned if they get a little tweaked. I take them off almost every day if the top isn’t off.
Purity’sPa
Brice
Houston TX
JLUR
Houston Car Stereo
It wasn’t cheap and they had a lot of issues integrating with the factory system. It’ll be a lot easier whenever the Alpine replacement deck is available.
It sounds pretty good but not sure the sound warranty the hefty price tag.
But as far as Houston Car Stereo goes, i can’t say enough positive about them. I’ve had systems in a bunch of vehicles during my life but this install was the most challenging for a lot of different reasons
Purity’sPa
Brice
Houston TX
JLUR
Houston Car Stereo
probablt not the Tuffy but I think it’ll work with the Vector GGB. I’ll let you know in a week or so.
