StaindReality
- David
- Aug 11, 2018
- Kansasncity
- Ram 1500 crew cab black out
Need help. So I put in the infinity 3.5 in dash. Sounded much better. So I order two more to replace the 3.5 in sb. The connector was a total different size so the metra harness wouldn’t work. It had black and white wire unlike colored in front also. Anyhow. I hook them up and put on bass blockers like the front. White to white. Black to black. Wired together. White positive black negative. (I assume)
Now. They work and sound nice and clear highs. Problem is. I all of a sudden have to much bass in front. Really don’t hear much in sb. It sounds weird. Don’t really know how to explain it. It’s like the bass on equalizer was turned to high as Can go.
Is it polarity? Was the white wires negative and black positive? Did I wire it wrong? Should I take blockers off sb? I’m not sure what happened but it actually sounds worse overall now even though the infinities sound nice.
