ASK US ANYTHING
Mx5red
Paul
San Diego
2020 JTR, 2020 JLUR
will you be coming out with new versions of your non-SAE lights? squadron pros, LP6s, etc. They are pretty awesome as-is (as where I think the SAE upgrade was necessary).
BajaDesigns
BajaDesigns
Rock Sponsor (Level 1)
San Marcos, Ca
Non-Applicable
It's in the works for the Squadrons and XLs, they will have backlight shhhhhh:fingerscrossed:
BajaDesigns
BajaDesigns
San Marcos, Ca
Non-Applicable
Will there be a BD flashlight?
There are a couple of companies that do it already but if you guys want it we might be able to pull some strings.
Hercules
Clearwater, FL
2012 Ram 2500 Longhorn, 2022 JLURD
I ordered a set of your sae amber fogs for my JLURD steel bumper like 3 months ago. Order number 113516. Land sarcia emailed me back in Jan saying that my order “for the old style sae fogs is being delayed, and I would be getting a new designed pair”. I’ve since emailed BD for an order status update after seeing the release of the new sae fogs online, but haven’t heard anything back. An you please tell me where my order is and when I can expect it to ship?
-Thanks in advance
COKENOGOOD
Hugh
Australia
JLUR-Black
To put LP6 on the stock steel bumper.
do I need to drill the existing holes to make them bigger?
BajaDesigns
BajaDesigns
San Marcos, Ca
Non-Applicable
-Thanks in advance
We are aiming to get all open orders for these lights out by the middle of April. With your order being at the top of this list it very likely will be heading your way by the end of this month.
Best,
Brandon
BajaDesigns
BajaDesigns
San Marcos, Ca
Non-Applicable
AFD
Northeastern US
2023 JL Rubicon (2DR/V6)
Yes, To utilize our LP6 on the stock bumper you will need to drill out the bolt hold to a 3/4 hole to accommodate the mounting hardware.
Wouldn't it also be possible to just remove the BD bolt from the mount and re-use the existing bolt from the steel bumper in it's place, possibly using a washer if needed?
BajaDesigns
BajaDesigns
San Marcos, Ca
Non-Applicable
You are able to use the stock bolt location. I was incorrect when responding. The only drilling that will be required is if the toggle harness is utilized.
Best,
Brandon
  • Like
Reactions: AFD
COKENOGOOD
Hugh
Australia
JLUR-Black
No, To utilize our LP6 on the stock bumper you will not need to drill into the bumper but if you are utilizing the toggle harness drilling for the switch will be required for a determined location.
https://www.bajadesigns.com/product...ator-2018-2022-wrangler-jl/?page=1&vid=153428
Best,
Brandon
Thank you so much for confirming.
Last question is. With upfitter wiring, I can wire low/high/back light to different OEM aux switches.
It would be safe to turn both low and high on at the same time?
I read it was not safe earlier.
BajaDesigns
BajaDesigns
San Marcos, Ca
Non-Applicable
The high beam and low beam will have to be wired onto separate switches. The high and low are not supposed to be on at the same time. If they are it will over power the light and cause issues down the road with the LEDS.
Best,
Brandon
