As usual, simple is not - brake help
Try mounting them both up with the rotor in place and install the caliper and pad on one side only. Look for signs the pads don't ride on the rotors correctly.
CorvZ061
Travis
Amarillo, TX
'24 JLUR 6MT
I’m pretty sure the brackets are the same side to side, the calipers make the difference.
Jeep Wrangler JL As usual, simple is not - brake help IMG_2753
Lofty
Casey
Ohio
JL Wrangler
Brackets don’t matter. Only calipers!
ScotM
ScotM
Scot
Southern California
2022 Jeep Willy's JL 2 Door
Spoke with a Jeep tech , and he was a bit stumped as to why they are different part numbers. He looked at the pictures from rock auto, and indeed there is a slight difference one of the bolt heads on the slider is galvanized, and one is shiny. Difficult to tell on a weathered Jeep, but I managed to tell the difference. Additionally he said in general the lower number stamp on two identical parts is the driver side
Jeep Wrangler JL As usual, simple is not - brake help IMG_0485
Lofty
Casey
Ohio
JL Wrangler
Looks like the lower one must have better corrosion resistance. Good find! For sure they would assemble and function on either side but it seems you have found your answer!
