Are all D-ring shackles the same?
Dusty Dude
Colorado Springs, CO
1970 Ply Roadrunner, 2010 Challenger SRT
There is a wide price range for shackles, but most seem to be the same 4.75 ton rating. I would like to get a couple of quality shackles that I don’t have to worry about breaking under load. Any recommendations or brands to avoid?
Pape
Quebec
JLU Sahara
Do your home work on this one. If you use a snatch block at full pulling you need to have a shackle that can handle double + your pulling power. In number if you have 12 000 LBS winch you need a 24 000 rated + on the other side of the snatch. Yes I know I did not factor any buffer but good D-ring have one build in.
And when I say home work I also include how to use them properly
KG4NEL
Jim
Hillsborough, NC
2025 Unlimited Rubicon X, 6spd, 4.88s
Crosby or Van Beest for me. Rigging isn't the place to cheap out.
OSCAR II
NJ
14 JKF
No they are not! Avoid Chinese. Dig a bit deeper. You get what you pay for. For starters:
https://www.mcmaster.com/products/d-rings/screw-pin-chain-shackles-for-lifting/
I deal with Mcmaster a lot and its their policy not to show the brand name of the products they carry. You can call them and they wont tell you. 99% of the you are getting name brand quality stuff, they have a reputation to uphold.
Ebay is another good place to look for Crosby shackles. I work with a lot if rigging equip so it is always on the truck. But there is that occasional oddball shackle needed and you just cant beat the price. Worth the look.
jac04
CT
2021 Mojave / 2014 JKRX
I use Crosby G-209A Alloy Screw Pin Shackles.
The 3/4" G-209A is rated at 14,000 lb WLL.
They can typically be purchased for about $60 each. IMO, you should only purchase from an authorized distributor to avoid cheap knock-offs.
