Anyone Running With Windshield Down
Troybilt
Troy
Ohio
troynemitz.smugmug.com
2012 JK Sport
Highway Dept
So I have ben wondering if anyone has been running with the windshield down? If so what experience have you had? Any problem with leaks after folding it back up?
RussJeep1
Westchester, NY
JLU Sahara
I've taken it down just to see how hard it is and if I could.
I couldn't: not because the process was difficult, as it's trivial: 4 bolts, especially compared to the JK, but because my passenger's wiper blade was frozen on.
1 Amazon windshield wiper puller device later, and the wiper blades off, it presented no issues. Regardless, I only needed it down a small amount to string ball bungees around to attach a sunshade, so the frozen wiper blade was not an obstacle.
There have been absolutely no leaks, even despite the presence of these bungee cords.
1quick1
Moderator
Moderator
2018 JLUS
I put mine down on Friday to install a sunshade and put it back up with no issues. The hardest part is lining the windshield wipers when putting them back on unless there's a trick I'm missing.
RussJeep1
Westchester, NY
JLU Sahara
There is. As per a YouTube video I saw, mark their position on the windshield by placing a bit of masking tape there prior to, and for the duration of their removal.
In my case the wipers came up to a low point on the windshield with a color change, so such tape wasn't needed.
jebjkey
Hawaii
Wrangler JL Unlimited Sport S
The windshield has built in markers for the wipers. There are sideways "T's" at the base of the windshield to mark the wiper position
Edit:
Here is a picture
Jeep Wrangler JL Anyone Running With Windshield Down IMG_0296
Troybilt
Troybilt
Troy
Ohio
2012 JK Sport
Highway Dept
Edit:
Here is a picture
That is going to be some handy information to have once I get my JT. Thanks for the info.
avnmech
Jose
Southwest Indiana
2018 JLU Sport S
I had my windshield down for a little bit, thing to remember when you put it back up, if you have a soft top is to loosen the front soft top rails, as you will have to manipulate them to get the windshield rubber seals on the upper corners back under them. This will prevent leaks. It's a couple of extra bolts, and a few more minutes of time, but over all it's way better than trying to drop the windshield on my JKU.
jhonn236_AZ
Jhonn
AZ
2018 JLU Sting Gray Rubicon
I did for a couple of days.
Pain in the behind to remove one of the wipers. After a LOT of WD-40 and extra strength I finally got it out. Also it was fun to line them back like factory. I think I'm off on one side but oh well.
Drove up to 49 mph and never saw the windshield ever move. I did not want to find out the max speed was though.
Jeep Wrangler JL Anyone Running With Windshield Down rubi!
OversandJL
Massachusetts
2018 JLUR, 2017 JKU Sahara, 2014 JKU Sport S, 2007 JKU Sport, 1997 TJ,
Was just going to add this hint. Good one
Therby
Taylor
Ontario, Canada
2018 JL sport 2dr
I was doing 45mph
Then this happened
Jeep Wrangler JL Anyone Running With Windshield Down 3DBEBD06-6314-4E41-A0A9-15D8864BC0D0
@JeepCares
WXman
Central Kentucky
I'll never know because it's illegal.
Jeep Wrangler JL Anyone Running With Windshield Down WindshieldLaw
Carlton
Chicago
Jeeps lots of jeeps
Driving 40+ plus with the windshield down??? It is only supposed to be down at low speeds offroad....
gofastguy
Ohio
2018 JL Rubi 2019 WK Trailhawk 2015 Mustang GT
OK...What's an "implement of husbandry"?
