Anyone else having issues getting anything to stick to interior plastic?
IdowaJeeper
Travis
Eastside of Washington state.
2024 Wrangler UL Sport S 4XE, 2024 Ram 2500 Crew Cab Cummins on 35s, Kodiak ATV.
I found a great cell phone holder that I used in my last vehicle that stuck to the side of the center console. Thought it would be great for the new Jeep.
Ordered a new one and it won't stick to the plastic in the Jeep. Ended up sticking it to the windshield.
Then, I had a bunch of little plastic clips that I used for routing cables and wires in the interior of my Tundra. They have double-sided 3M tape and work great.
But they won't stick to the plastic of the Jeep. Bought an external mount toggle switch with double-sided tape and it won't stick to the dash.
I had some leftover heavy-duty fabric reinforced gel double-sided tape from a project earlier in the year, and it ended up sticking to the plastic. Unfortunately, I only had a couple of pieces left. No idea of the name brand or where I bought it; either Walmart or the Ace hardware store. Went to both places tonight and couldn't find it.
Has anyone else had trouble getting normal double-sided tape to stick? What brand did you find that works?
Brand new 2024 with no Armor-all applied or any other spray. I even tried cleaning the spots with alcohol wipes and no difference. It's odd. Never had this issue before.
I need to route a few CB cables and wires from other accessories, so need to either find the tape I used, or another solution.
Mike_Hawk
Illinois
2022 GOBI JLUR 3.6
Mechanical Engineer
If you find a better sticky stuff that isn't permanent I'm all ears, good luck!
Willys41
Larry
Pleasanton Ca.
2020 Jeep Willys
This works pretty good.
First put down the clear and then stick you item ontop of the clear tape.
Clean area with alcohol.
https://www.amazon.com/Pack-Double-...f+removable+double+sided+,aps,155&sr=8-6&th=1
Opus
Midwest US
www.jlwranglerforums.com
My Quad-Lock phone holder had a disc of 3M tape and so far (2 years) it has held great. Mine is on a vertical face on the dash. If you're mounting to the top of the dash heat might be affecting adhesion.
Jeep Wrangler JL Anyone else having issues getting anything to stick to interior plastic? IMG_1075
Blues Fan 30
St. Louis
Yep I tried taping off around the air vents to plastidip the "chrome" vent rings but tape does not stick at all. Tried duct tape, gorilla tape, scotch tape....nothing even acted like it was sticky in the least just fell right off.
THAW
Foster
23 JL4DrRubicon
It helps to (gently/carefully) heat up the tape and plastic with a heat gun (or hair dryer) prior to install.
MountainRigged
Jeep Wrangler 23' JLUR 3.0L EcoDiesel
All the tape stuff has failed on trails with all the tossing eventually for me. Ended up doing the dash Mounts that screw in to the tray up top.
ForgottenTaco
CT
‘23 Sarge Green JLU Willys
I just used some of this gorilla tape to mount my old weather tech cup phone to a metal center console in my work car which is a recycled cop car. The metal console was freezing cold and dusty. Tape stuck to it with no issue.
https://a.co/d/5fXrmG4
IdowaJeeper
IdowaJeeper
Travis
Yeah, was looking into that, but, 4xe, so no bueno...
Jeep Wrangler JL Anyone else having issues getting anything to stick to interior plastic? %2Fuploads%2F2023%2F06%2FGJ204JeepWrangler--scaled
jwms
U.S.
Jeep Wrangler
I have had troubles and even reached out to 3M in the past. I have a set of ARB lights with a light switch toggle on my dash that is always loose or falling off. I described that the interior trim is almost a vinyl-ish plastic that is slick - as if it is always coated with a lubricant.
They suggested - and I think every accessory comes with - 3M VHB 59## tape (I can't remember the specific). I had ordered a small roll of it on Amazon because 3M only sells it in bulk and it's very expensive. I can't say that I trust the smaller rolls on Amazon- they must either be knock-off products or resold, old inventory because it didn't stick.
Regardless, I really wanted an opinion from the people who understand the chemistry of what adhesive sticks to what surface.
I think you'd have to go to some shop that does stereo work or something and see if they use it and can sell you a fresh piece off of their roll. Otherwise, I just keep buying random other brands off of Amazon until something sticks.
Tech Tim
Summit Sponsor (Level 3)
Tim
Poulsbo, WA
4x4 of all kinds
Part of the Northridge4x4 team
^^^This is the magic trick right here^^^
After getting things very clean with alcohol (I use denatured), I get out the heat gun and make sure the plastic is warm and the adhesive is hot.
3M double sided tape for the win.
I've never tried the adhesive promoter mentioned above, but it may be worth the effort.
Earl-Girl
Bob
Northern Virginia and North Carolina OBX
2021 Gladiator Overland; 2024 Wrangler Sport S; 2025 Gladiator Mojave
Not sure if this will help…I have a 2024 and I used these for cable management. Adhesive has held up for a year now. Doesn’t answer your phone mount issue, but it answers the stick to the plastic question. Good luck.
https://a.co/d/eUWKl98
Jeep Wrangler JL Anyone else having issues getting anything to stick to interior plastic? IMG_1863
