Any service suggestions?
ImAJeepskate
Grant
Minnesota
2018 Jeep Wrangler Unlimited Sport (JLU)
I am doing an axle swap in the next week or so, is there anything else I should be doing to my jeep while I have my axles out?
ImAJeepskate
ImAJeepskate
Grant
Minnesota
There’s a ton of things you can do. What’s the game plan?
Unbolting the "old" axles and bolting in the new ones. Swapping out some tired springs in the rear and then bolting in the new axles. Just seeing if there is any service work that will be way easier with the axles out.
GerJL
Arizona
None
Inspect the control arm joints for wear and tear and perhaps tie rod and drag link if you are keep the same ones.
ImAJeepskate
ImAJeepskate
Grant
Minnesota
New tie rod and drag link but will look at control arms for sure
Maverick909
I.E.
www.instagram.com
keep an eye on the brake lines as well with the 3/4" wider axles each way
Maverick909
I.E.
www.instagram.com
