roaniecowpony
Brother calls me yesterday, says the fan is not running on his jeep. Apparently, I am forever tied to this jeep.
I figure it's one of three things, Z-case fuse, Green CAN bus junction block, or the aftermarket fan controller. I load up a carbon pile tester as well as an electronic battery tester, multimeter, spare fan, Z-case fuse, CAN bus block, and the usual tools. Get to his house and it's just barely under 100F. No shade to work in. This is elderly abuse. Brother offers water. I decline, since wife packed up two thermos' with ice water and a couple plastic bottles for the drive. Peeing was more on my mind.
Brother suspects it's the aftermarket fan controller. He thinks we should remove it. I have no reason to argue. Since I've installed a few of these and removed one other, I'm elected for the labor. It didn't go quite as fast in 100F as the last one I removed in the cool of winter. Got the PCM wiring back to original configuration. Started it, and the fan came on. Not a big surprise. Took it for a drive and the fan was working fine running off the PCM control.
Brother wanted to look inside the Fan Controller that has been on for about a year now, under previous ownership.
