Another Jeep won't start issue
5Ma
Philadelphia
Rubicon JLU
I was driving my 2018 Jeep JLUR just fine all day. I went to Costco, came back home and turn off the engine to unload my groceries. The min that's done (which was about 10-15mins), I wanted to head back out to pick up my kids and the Jeep won't start. All electric and dash is on, but it won't crank. I scan through this forum and a lot of people pointed to the batteries. At this point, I try starting the Jeep about 3 times so when I tested the batteries, both show about 12.2 volts. I went ahead and bought new batteries and changed both batteries anyway just to see what happen, but the problem still persist. I had it towed to the dealership and today, they told me I have a failed Starter.
My question is, how can a starter malfunction? Did I just got a bad starter from manufacturer, or did I do something to cause it? Can low or dead batteries cause a starter to fail?
kah.mun.rah
Merenkahre Jr.
Duat
How many miles do you have on your Jeep? Do you use your auto start/stop at red lights? Do you offroad in water? The one on our JK lasted over 200K miles but a starter only "has" to last 36K miles.
5Ma
5Ma
Philadelphia
Rubicon JLU
I have about 55k miles. Yes, I do use the stop/stop. I’ve learn to ignore it.
no, I have not been off-roading.
three of my previous cars were 200k miles or more before owning the Jeep and I haven’t encounter a starter failing so I’m just wondering if I got a bad starter or I’ve did something to cause it to fail. Or some other component on the Jeep is causing it.
kah.mun.rah
Merenkahre Jr.
Duat
Think of each time the start/stop uses the starter as an additional day in the Jeep's starter's life. If in your previous cars the starter was used once a day and 200K miles. Now you use the auto start/stop 4 times a day so when you times that by 55K miles it puts you over 200K miles.
If that didn't make sense here is another way to look at it.
- Assume you start once a day and drive 10 miles a day. After 200K miles the starter was used 20,000 times.
- Assume that you start and use the auto start/stop 4 times a day and drive 10 miles. After 55K miles the starter was used 5,500 x 4 = 22,000 times.
Deleted member 59498
Guest
This has always bothered me about start stop. Starters have a finite life span and using it 4 5 or even more times a day to start the engine seems like it would lower that life span.
kah.mun.rah
Merenkahre Jr.
Duat
Yep. One of the advantages of the e-Torque version, it only uses the starter at the initial start and not with each start/stop. In my older JL (before I got the Tazer) and in my other cars I press the ignition button and then then the "Avenger" button soon after to turn off the start/stop to save the wear and tear on my starter.
