Gorilla57
- Jan 3, 2019
- Chandler AZ
- 2019 JLUR Mojito
Lots of variables to consider when deciding on the correct ratio for you. Weight, altitude, speeds, etc. I originally went with 4.88's with my 37's and it was ok. It would struggle a bit running up the roads to Flagstaff or Show Low when loaded down with all the camping supplies. I then did the Livernois tune and it helped a ton, but still wasn't "happy" with it. I had a pinion bearing go out (due to shitty install from a shop here in PHX) and had 5.13's installed. I couldn't be happier, getting the same mpg, or slightly better, as the 4.88's and I can actually pass people now on the 2 lane roads at elevation.
