levessh
I wanted to see if anyone else had been able to get this to work on a 2021. As far as I can tell there are 2 wires that appear to be different from the 2020 update. The violet for the drivers door and the violet /yellow for the passenger rear door don’t appear to be on the white connector. If anyone could take a couple of pics (I know its a pain) of the 4 wire tap connections in the passenger panel I would really appreciate it.
These appear to be the same:
Violet / White wire on the Blue Connector
Violet / Gray wire on the White Connector
These are the two that appear different
Violet Wire that should connect to the purple wire on the AMP harness
Violet / Yellow wire that should connect to the yellow wire on the AMP harness
