Amp Just for Speakers ?
BrentMG
Brent
Central Texas
23 JLUR XR
So I have done some reading and from the sounds of it, even after changing out your stock speakers you're still limited and not getting the full potential of your upgrade. I have the premium sound and I swapped the top dash speakers for the MB Quarts and replaced the sound bar speakers with some 6.5 Kickers.
I just recently purchased a JBL stage A6002 dirt cheap. Will this help with my current set up? If so, what else will I need to make it work? TIA
lashlee
Knoxville, TN
'18 JLUR 2.0 Turbo 4 (Sold), Tesla M3P
It's a two channel amp so you'll have to decide which pair of speakers you'll be powering. The amp accepts high level inputs so you can simply tie onto the OEM speaker wire and feed the signal into the amp. Don't forget to run the power wire into the engine bay to the battery and use a fuse within 18" of the battery.
