Alignment Post Rubicon lift Unstallation
ResqFE
Ron
Ensenada Baja MX
2018 JL Unlimited
I am thinking of eventually buying a Rubicon lift down the road to install on my Sport. Will I need to do a alignment afterwards?
I'm assuming with with a aftermarket one, not sure about this mod. Thanks
Swanny297
NELA
2018 JL
Mine didn’t need one with a 2.5” lift they checked alignment and showed me the report, I had to adjust my steering wheel position a little it was a bit off center.
ResqFE
ResqFE
Ron
Ensenada Baja MX
2018 JL Unlimited
Did you do the install yourself? Anything too complicated?
txbonds
2018 Wrangler Sport JL
Just got my rubicon lift put on. How do you adjust the steering wheel on these? Was going to take it for alignment and ask them to do it. Is it easy?
Spank
It's incredibly easy. You just loosen the bolt on the drag link and twist the bar until your wheel is centered, then retighten the bolt. It may take a few tries to get it just right, but I wouldn't take it to a shop if you're looking to just adjust that one thing. You can do it in your garage with simple hand tools.
Here's a photo of the drag link on the JK. The JL's drag link has a single bolt (where as the JK had two), but the position and method for adjustment is exactly the same.
Jeep Wrangler JL Alignment Post Rubicon lift Unstallation jk-alignment
txbonds
That’s awesome. Thanks.
