AEV 2 inch spacer lift alignment
hawk68
Will
Pennsylvania
2024 Willys 4 door
I had alignment done today after I had done the spacer lift. Here is the results. Is there anything I should be changing? I also added Clayton front adjustable track bar and AEV geometry brackets. Appreciate any input.
Jeep Wrangler JL AEV 2 inch spacer lift alignment IMG_4112
jadmt
jeff
montana
they left off the most important reading, the caster......
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
That, and they didn't do anything but adjust the drag link to center the steering wheel. Toe is same before/after.
Roky
Roky
Alignment shop when they see a jeep come in…….then notice the customer watching……
Jeep Wrangler JL AEV 2 inch spacer lift alignment IMG_9893
Alignment sheet looks good OP, take it back and tell them to give you the caster numbers….
GATORB8
CLT NC
Bring the instructions so they know the orientation of the Geobracket caster adjustment. If it's low, have them bump to the next setting.
Jeep Wrangler JL AEV 2 inch spacer lift alignment 1711995160823-yh
hawk68
Will
Pennsylvania
2024 Willys 4 door
I didn't see the caster until you guys mentioned it. I was in a hurry. Duh. I used the Klein angle finder I read from other post. This is my first jeep. Its saying 90.
GATORB8
CLT NC
Nice, that should be 6 degrees IIRC (the 6 degrees is built into the housing). You should be solid if it's driving nice.
jadmt
jeff
montana
remember when you use an angle finder the grade of the garage floor has to be taken into account. as was said I would take it back and ask for the caster number.
