IPvFletch
LOL well yes, both of them were out for about a 20min ride back home. I was more worried about the plastic bushing spacer things poppining out but they held in place on their own. There's I think maybe 10 body bolts like this keeping the body in lined up and tight with the frame. The others were all tight, so it was just the 2 front bolts which were out. It was no big deal, and nothing got out of alignment.Are you driving around with the bolts out?
Yeah, I don't think the heat would have made it up to the threads anyways.No heat, just a breaker bar? I really want to add a set of ACE rock rails to my JLUR but I am terrified about breaking these bolts.
The pinging sound I want to think was the nut creaking, but it could have been his ratchet - he was using a big long ratchet, much longer than the one I had.
LOL well we looked at them real close and after a good cleanup they are fine. I cleaned them good and while some of the threads look scratched up, they are in great shape, with no big sections cut out or anything like that.I would NOT re-use those. Buy equivalent grade/length and install new ones.
BTW, Carb/Parts Cleaner seemed to all but dissolve the threadlock. It came right off with just the force of the spray. But I scrubbed them good afterwards and screwed them through a rag too make sure the threads were nice and clean. I also markered them so I knew which ones were Front Middle and Rear, and which front bolt was D and P. This was just in case it helped fitment when I went to put them back in.
Update: I just put them all back in and they went in like butter. Much better w/out all the loctite gunk built up. I torqued everything down to 80 ft-lbs with my jumbo torque wrench.
