Adding Heated Seats to 2018 JLU with Leather
GOBOGIE
Little Lake in the Middle of Nowhere
2007 FJ with 301k and counting - Energizer Bunny
I’ve had a very similar if not the exact same set up on my FJ. 12 years and just under 300,000 miles and it’s still burning my butt
Gaust
Todd
Portland, Oregon
2018 Wrangler JLU Rubicon, 2018 Renegade Trailhawk
Heated seat install isn’t too hard or bad to do yourself if you do your research. There’s some good YouTube videos. Kits are around $100 a seat and you can pick the location of the switches yourself. I may be a little biased though as I prefer to do most projects myself, especially electronics. Fifteen years installing 12 volt electronics when I was younger helps even if I’m a bit rusty at times.
mjwilson12379
Michael
Maryland
2018 JLU Sahara
This is the pick aftermarket sent me
Any install pics or suggestions on that setup? I'm about to put mine in. Kinda like that location. Where did you wire it into, if you don't mind me asking. Was thinking of taking it all the way to the fuse panel and tapping into an accessory/run circuit. But would like to keep it straight inside the cabin area vs. pushing more wiring through.
