Adding a Steel Bumper - Advice
georgej
George
NY
2026 Willys, 2023 Willys Unlimited 4XE turned in
Just picked up a 2026 Willy's. I thinking of adding an after market steel bumper - a lot of deer where I live - I was looking at the Barricade Trail Force HD Front Bumper from Extreme Terrain.
It weighs (as stated in the description) 79 lbs.
Would I get any sag up front?
I read somewhere that the stock Willy 2026 is steel under the plastic wrap (haven't gotten around to looking) too cold this week.
So if it has some girth to it I'm hoping I don't need to do anything in order not to loose the extra height the new Willys provides.
Any advice from someone with a similar set-up.
Thanks,
George
jadmt
jeff
montana
no not really there is a small thin steal stamped piece that weighs about 2lbs... the bumper is about 10lbs total :) look under at the brackets they are soap can thin.
Jeep Wrangler JL Adding a Steel Bumper - Advice tempImageQOGii9
georgej
George
NY
Thanks
wharton [SCAMMER]
Adam R
Oklahoma
2023 Rubicon 392 XR, 2022 JT sahara
79 lbs up front usually won’t cause noticeable sag on a stock Willys, especially if you’re not adding a winch. Most people don’t see a drop until you’re closer to 120–150 lbs total.
You’re right that the Willys has a steel bumper under the plastic cover, so the net weight gain isn’t as big as it sounds. You should keep the factory rake and height just fine. If you later add a winch, that’s when spacers or heavier springs might be worth considering.
azjl#3
North AZ
I put 600lbs of lead acid batteries in back to swap for new ones. Jeep dropped 1/4 inch.
jadmt
jeff
montana
not really it is a thin steel piece that weighs 3.97 lbs I did not weigh the intact bumper but it was not much. I cut mine up to throw it away. the thin 3.97lb is the only metal in the rear bumper.
Jeep Wrangler JL Adding a Steel Bumper - Advice IMG_9868
Jeep Wrangler JL Adding a Steel Bumper - Advice tempImageLoyxrZ
