Adding a second 12v usb outlet in cargo area.
Waxings
Omaha
2022 Jeep Wrangler High Tide
Does anyone know if there is room in the driver side trim panel, in the cargo area, for a second 12v outlet. Outlets are typically about 1-1/2 to 2” deep. I’m not sure it there is an area with that kind of clearance?
thanks
Terrymo
Terry
2023 JLURXR 3.6 ET
@dstevens did this
Installed an extra power outlet in the left rear. There is a factory power outlet on the left rear already, but it is unusable because the plug and wiring sticks straight out into the cargo area.
As a note it is non trivial to find a spot deep enough for a power outer. I spent about two hours looking and the best I could do with this spot, which was on a slight angle as the mouting point is not flat.
As a side note there is a large unused area on the left side just in front of the rear seat belt. It has a large white plastic spacer to make it the same height as the right side with subwoofer. Seems like Jeep could have easily made a nice little storage box there. I fell like stashing something in there just to use the space but removing the trim is a bit of a pain, and the clips will break eventually.
