5 service errors at once.
NCWrangler
Marshall
North Carolina
2018 wrangler unlimited sport
On my way to work the dashboard lit up and all of my gages went to 0.
I finished my drive to work and red through the saved messages.
1. Service 4wd
2. Service shifter
3. Service ABS
4. Service stop/start
5. Service stability control system
I turned the vehicle off and went into work. Trying to leave work the vehicle starts but will not shift out of park. The only thing I have tried is pushing all of the loose fuses in. I have seen many others with similar codes but no one has said the vehicle won’t shift/drive. Every time I turn the vehicle on all of the codes come back on. Anyone else?
RoadiJeff
St. Louis
2020 2.0T Recon, 2018 3.6L GC High Altitude
Since you already checked for fuses not seated all the way, the next step I'd recommend is to check for a loose battery cable.
Rico1111
Rico
RI
2018 Rubicon 2 door JL
It may be one or both batteries going bad....usually the sign of them going is multiple service codes lighting up or electrical going haywire like wipers going etc... they say to change them out every 3 years.
Milfmaker
Wayne
Virginia
2018 Jeep wrangler jl
I have the same issues with all the same dash lights. I have recently replaced both batteries. Was told my front left brake sensor wasn’t communicating with the cpu. The lights don’t come on every time I drive and of course never throws any code when at the dealership. Could this all be from a sensor gone bad?
