- Jul 4, 2018
- San Marcos, Ca
- Non-Applicable
4x4 sPOD Wireless Units
Are you tired of fishing those wires through your firewall, cutting into preexisting wire loom boots, or drilling holes in your dash to mount a switch panel in the cab? Here at 4x4 sPOD, we felt it was time to eliminate those headaches and offer a fully Bluetooth unit for those who would rather have the luxury of running their accessories full of their phones and tablets. These options eliminate the headache of mounting the controller in the cab allowing more room for future mods and retaining that factory interior look.
BantamX, Non-Switch Panel Systems
The BantamX non-switch panel system is designed to be paired with the sPOD™ app on your phone or tablet, saving hours of wiring & installation time! It is a small, 8-circuit (expandable) control system that provides a clean and safe way to power and control 12/24VDC accessories. Due to the small footprint of the BantamX, the placement options are endless!
Pair the BantamX with the sPOD app on your phone or tablet, you have a controller that can be used anywhere. Backed by sPOD’s 5-year manufacturer warranty*, stay in control with your sPOD™ BantamX control system.
The 36” setups includes the following:
(1) BantamX System
(1) 36” Battery Cable Set
(1) Universal Mounting Bracket
All necessary hardware
The 84” setups includes the following:
(1) BantamX System
(1) 84” Battery Cable Set
5-year Manufacturer Warranty
Specs for the BantamX:
8 circuits rated at 30 amps at 12.5 VDC per circuit
16-position terminal block
2 controller ports (RJ45) for Ethernet cables
Integrated low voltage cutoff battery protection w/ optional override
100 amp in-line fuse
Operates on 12 VDC or 24 VDC
Built-in Bluetooth capabilities for remote control
Configurations:
BantamX, Non-Switch Panel, Uni w/ 36" Battery Cables | PN: 87-0114 MSRP: $604.95
BantamX, Non-Switch Panel, Uni w/ 84" Battery Cables | PN: 87-0115 MSRP: $624.95
Link: https://www.bajadesigns.com/products/spod-bantamx-non-switch-panel-universal/?sku=870114
SourceLT, Non-Switch Panel Systems
The SourceLT non-switch panel system is designed to be paired with the sPOD™ app on your phone or tablet, saving hours of wiring & installation time! It is a small, solid-state 6-circuit control system that provides a clean and safe way to power and control 12VDC accessories. Due to the small footprint of the SourceLT, the placement options are endless!
Pair the Source LT with the sPOD™ app on your phone or tablet, you have a controller that can be used anywhere. Backed by sPOD's 5-year manufacturer warranty*, stay in control with your sPOD SourceLT control system.
(1) SourceLT System
(1) SourceLT System
Specs for the SourceLT:
6 circuits rated at 30 amps at 12.5 VDC per circuit
12-position terminal block
Configurations:
SourceLT, Non-Switch Panel, Uni w/ 36" Battery Cables | PN: 87-0116 MSRP: $499.95
SourceLT, Non-Switch Panel, Uni w/ 84" Battery Cables | PN: 87-0117 MSRP: $519.95
Link: sPOD SourceLT, Non-Switch Panel - Universal - Baja Designs - Off-Road LED & Laser Lights | Automotive, Jeep, Truck, UTV, ADV, Dirtbike
(1) BantamX System
(1) BantamX System
Configurations:
(1) SourceLT System
(1) SourceLT System
Configurations:
