4H engage - gear grinding
Hecs
Hector
Alberta Canada
Jeep Wrangler Rubicon 2020
Hi Everyone!
I have a Rubi 2020, Just 2 days ago I tried to engaged 2H to 4H with the speed of 15km/hr but it was really really hard but I was able to moved it at the end, but then I’ve heard gear grinding.
Is there anyone here has got the same experience or same problem with mine? I love to hear some advices or solutions of the problem.
Thank you.
calemasters
Allen
Springfield, Mo.
2026 Moab 392 w/27X package & Escalade
Retired Mechanical Engineer
Gear grinding is not normal for 2H to 4H at lower speeds (below 70 km/hr). Are you sure it was fully engaged in 4H? You may want to try again to see if it is repeatable.
Hecs
Hecs
Hector
Alberta Canada
Thank you for your quick reply.
I think it was not fully engaged coz by the time I’ve heard the grinding, I released it and back to 2H. It happened only once but I was worried if something broken. Thanks again.
Black Jeep Convertible
NYC
www.amazon.com
'19 JLU Sport S 2.0T eTorque
Amazon Influencer 😂
It has happened to me once while parallel parking and switching back and forth between 2h4h. Once in a blue moon it just doesn’t fall in place when not driving straight
wibornz
Ted
lansing, Mi.
www.instagram.com
JL Unlimited Rubicon
When they are new, the transfer case is very stiff. The more you use it the easier it will become. On the roll, just let off the gas and pull it back into 4h, You can do this several times a day to smooth out the process. It will become easier. The grinding was you not having it fully engaged.
Hecs
Hecs
Hector
Alberta Canada
Thank You
I was just worried if something was broken..
thanks again..
