4 Pin Tow Harness Specifics
RussJeep1
Westchester, NY
JLU Sahara
  • Thread starter
  • Banned
  • #1
Please let me know if I am wrong.
Currently, there is no plug and play solution to wiring a 4 (not a 7) pin wiring harness to the aftermarket rear hitch on a JL correct--just the kit to do both 4 and 7 pin type harnesses, snaking wires to the engine compartment, correct?
Guys like this have taken the JK 4 wire kit and spliced it into the tail lights, as the connectors on the JK and JL are not compatible, but again, no dedicated 4 pin plug and play method we know of yet, right?
Here's what I don't understand, back in the JK days was it sufficient to plug this 4 pin connector merely into the driver's side tail light to get left (driver's) and right (passenger's) turn signals (correct?), running lights and ground, or did one have to also get to the passenger's side direction signal wire from the passenger's side tail light, even if no spicing was involved?
Thanks.
Rick12785
Rick
Charlotte, NC
2018 JL Sahara
Tekonsha has a wiring set (4 pin) that is supposed to be plug & play for the JL. The only difference is you run one wire directly to the battery to take the draw away from the LED's. Part # is 118782. I know eTrailer has them but would never recommend you buy from them. I'm surprised no one has posted that they've installed it. I will if I ever get my JL.
RussJeep1
Westchester, NY
JLU Sahara
  • Thread starter
  • Banned
  • #3
Thanks for the info and warning Rick.
Let me ask you, if you did NOT have LED back lights on your JL, as I don't have (I didn't opt for them, the AD6 factory code lights in my factory order), would you be less concerned with the power draw issues of using this part sans the dedicated direct-to-the battery wire?
Rick12785
Rick
Charlotte, NC
2018 JL Sahara
This will be my 1st experience with LED's but I would say yes, I did a T connection 4 pin on my JK and there was no wire run to the battery. I read on here there was concern over splicing into the LED wiring because it is much thinner than standard.
mergedown
Jason
Columbus, OH
2018 JLU Sahara
I installed the OEM Harness on my JL a couple weeks ago, and I do have the LED package. Even with the OEM harness, you are still required to run a harness from the right tail light to the left tail light. Even the video that PO posted with the JK harness install on a JL shows the need to run from both tail lights.
I've leased my Jeep, so I chose to install all OEM at this point, and I had a bit of an immediate towing need, so my options were limited. I did NOT want to splice into wires, which the OEM solution does not require.
WXman
Central Kentucky
I ordered the Mopar "pig tail" for $35 bucks which is supposed to be plug and play, and then you can splice whatever 4-pin connector onto the end of the wires you want to. Usually Walmart sells the 4-pins dirt cheap.
I'll be reviewing it as soon as it shows up at my house.
Rick12785
Rick
Charlotte, NC
2018 JL Sahara
Do you happen to know the part #? Not sure I have seen this yet. Thanks.
WXman
Central Kentucky
I don't have it readily available but I'll include it in my review.
TIDALWAVE
CHUCK
MINNESOTA
2015 Mustang GT Convertible, 2013 CHEVY SILVERADO, 2018 JLUR
Someone mentioned that the LED wiring harness is smaller gauge than the incandescent wiring. I have ordered the LED taillight package/tow package and plan to tow my boat. The boat trailer uses standard incandescent bulbs...will the trail lights stress the LED lights on the Jeep?
Specter491
'18 Wranlger JL Sport S
I'm also interested in installing just a 4 pin harness but I don't want to have to splice cables. Does a plug n play 4 pin harness exist for the JK? Is it only a matter of time until something comes out for the JL?
digitalbliss
North Alabama
2018 JLUR, 1979 CJ7
If you ordered the tow package then the answer is no.
arjusmc
Tony
Spanish Fort, Al
Ocean blue JL Unlimited Sport S
Will you still need to run a wire to the battery if you have a sport with the standard tail lights?
d3vils-advocate
2018 Wrangler JLU, 1976 CJ5
Firefighter
Did you ever find the part number for the mopar pig tail? I hadn't heard that there was one. Thanks
WXman
Central Kentucky
The harness I bought wasn't what I expected. To my knowledge there is still no 100% plug and play option for adding a 4-pin harness. You'll need to do some wiring for power, ground, and connections at the rear of the Jeep with one of the aftermarket kits.
Bubba33
Saint Louis, MO
18 jeep wrangler Sahara JL
There is the one that uses a power wire to the battery. Some have said you can get the power from the 12 volt outlet in the back. I'm going to look into this.
