392 Rim question
Monty 4xe
Germany
2021 JLU 4xe
Hi,
I cannot find any details about the 392 17“x7.5“ bronze JL wheels.
I need to know the load capacity and there is no lbs stamp on them. Does someone know where I get this info? Jeep cares was not able to help.
This is the partnumber 68508685AB
Maybe I had some luck and someone has a pdf file of knows another stamp for it.
with kind regards
Jeep Wrangler JL 392 Rim question IMG_2511
yokramer
Snark Incarnate
Are you trying to put them on a semi?
Monty 4xe
Germany
2021 JLU 4xe
For my 4xe… same sizes as the rubicon rims .
aegisdrgn
Los Angeles
2024 Wrangler Rubicon X 4xe
If you're worried whether it will support your 4xe. Don't worry the 392 weighs just as much and it comes as standard wheels for the XR.
Monty 4xe
Germany
2021 JLU 4xe
Yes but for legalization here I need theöbs number on pdf or stamp
jadmt
jeff
montana
I see the issue he is from Germany and they have some really stringent TUV rules...
Monty 4xe
Germany
2021 JLU 4xe
Ohhhh yes. But maybe someone with mopar parts software might see details
yokramer
Snark Incarnate
Monty 4xe
Germany
2021 JLU 4xe
Will try to reach him … thanks . Any other idea? What are all those stamped numbers on the inner side and why no load range etc lbs ?
2nd 392
Ca
Long shot, do you know what the “BCD” stamp is in reference to ? If you get to use them do beware mine faded to gray in ~4 years. Maybe you could seal or protect them since they are still bronze.
Monty 4xe
Germany
2021 JLU 4xe
So you mean adding a stamp on my own?
aegisdrgn
Los Angeles
I think it's because Mopar didn't intend to sell them individually as aftermarket wheels for other vehicles - so it's certified for specific Jeep models only.
Monty 4xe
Germany
2021 JLU 4xe
Yes but maybe someone has build specs of the rims … an it is still same JL
Monty 4xe
Germany
2021 JLU 4xe
Ok BCD means ? Lbs value?
