Chris1349
I have 2019 Jl 3.6, started having code p0304, and rough idle at cold start up then it would run smooth after warm up. Changed all plugs and coil packs under intake. Ran good for couple days then started back with rough idle and p0304. Went back pulled plugs and number 4 cylinder spark plug was wet. Next changed injector, got all back together, ran good for couple days, then back to rough idle and throwing code. Checked compression and all cylinders is 150. Any ideas or help would be appreciated. Thank you.
