BillyHW
Thought experiment: Imagine a frictionless tire and the most robust regenerative braking system imaginable. You're not stopping.I can see the OP's logic. How much energy is needed to stop a moving car? What is stopping the vehicle? Heat from brake pad/rotor friction, tire friction, other internal friction (engine), and aerodynamic drag. Add a hybrid system and less energy needs to be dissipated by the other components, including at the tire/road interface. Less friction between the tire and road should increase tire life. Not sure how much difference it makes though.
The tire is there to provide traction, not braking. It's there to provide the most traction possible so that maximum braking can be applied (without skidding), whether in the brake pads/rotors or regenerative motor, or combination of both.
