3.6L Auto vs 2.0L Auto
Between the 3.6L& 2.0L which one do you like better?
  • Total voters
    189
  • Poll closed .
Matthew/E36
Classified
StL
Two Thousand and Eighteen Jeep Wrangler Unlimited
I can see the OP's logic. How much energy is needed to stop a moving car? What is stopping the vehicle? Heat from brake pad/rotor friction, tire friction, other internal friction (engine), and aerodynamic drag. Add a hybrid system and less energy needs to be dissipated by the other components, including at the tire/road interface. Less friction between the tire and road should increase tire life. Not sure how much difference it makes though.
The tires are always going to slow the car down. Whatever does the "braking", it's the tires that slow the vehicle relative to the ground.
Wondering if the tires are lower resistance or harder compounds that last longer.
EDIT: also regen braking stretches out the time to stop which would reduce tire wire to some degree.
DanW
I head the Aluminum blocks are cracking on the new 2.0l motors and fca is having problems with them.. they are currently looking to move that motor from the Trenton plant to dundee to see if they can fix the problem.. this was info i got from someone who works at the Trenton plant now with the new 2.0L motors. I was worried that the new motor will have nothing but problems.. FCA better get that fixed quick. Going with the more reliable v6 here.
I think if that were true, they wouldn't be opening up orders for them. To move production of an engine would require hundreds of millions of dollars. Why would changing locations make a difference, anyway?
Raskass77
Casey
Dearborn Heights, MI
2021 Jeep wrangler 392
CDJR Sales Consultant
Dundee already works with 4cyl motors so they are trying to see if they can fix the problem they are having because Trenton plant can’t find a fix yet and they never worked on 4cyl motors before.
DanW
Ok, well that's different than moving production. That makes more sense. I still don't think they'd open up customer orders if they had a significant problem, especially if there is no solution in sight. They have plenty of capacity for 3.6 engines to make up for a shortage of 2.0's, if there is a problem. If there is one, I hope they figure it out and fix it fast.
BaldEagle
Seth
Los Angeles
2018 Black Jeep Wrangler Rubicon jl
Do you trust the 2.0.turbo VS V6
DanW
Nope. Not until it is proven. It is a Fiat based design. The V6 is proven to be reliable and durable.
$uicide$hift
Masshole
This right here! It may be a great engine but until it is out on the road and gets a lot of miles on it I would not want to buy it. The V6 is proven and if the 4 cylinder Turbo turns out to be a great engine it will be an excuse to trade in and buy one with that engine down the road after it has proven itself.
Until many are sold and get some good miles under them nobody knows how good this engine may be or not.
kingdog23
Phil
CT
2019 JL Bikini Sahara Turbo, 2016 Mini Cooper S Clubman
LED Lighting
Though perfectly in line with expectations of how a tinyturbo4 would perform pushing a brick into the wind. The 2.0T benefits in the city where it gets greatly improved fuel economy, but not on the highway, where even under rather easy EPA testing that averages 48MPH and nevers crests above 60, the 2.0T becomes about as fuel efficient as the 3.6L Pentastar. It’s highly likely under the EPA’s US06 testing where the speeds are more realistic highway speeds, the 2.0T would do worse than the Pentastar, but they don’t put that number front and centre when publishing results.
This is very much inline with the characteristics seen in similar platforms/setups.
Bingo! The turbo will gain 1-2 mpg in the city and 0-1 on the highway; 1 mpg overall and $3000 more. It just doesn't make sense, especially if you want a stick and drive 75 mph on the highway like me. I hope to see the BSG paired with the V6 in the future for city driving and trails. Highway numbers over 25 for a JLU are a pipe dream. Your posts are great. Thanks!
BaldEagle
Seth
Los Angeles
wait - is the 2.0T the same engine as in the Alfa Romeo Giulia?
Test drove it today not that impressed just fast off line turbo kicks in at 20-30 like the balls of v6
DanW
You drove the Alfa or a JL with the 2.0??
BaldEagle
Seth
Los Angeles
I feel outside of fuel I see. No point it does not blow away the V6 seems tve v6 is made for Wrangler 2.0 has not figured out its place yet
BaldEagle
Seth
Los Angeles
Exactly tested. It today in a Alpha you are correct upper speeds it flattens out
BaldEagle
Seth
Los Angeles
I am not getting a Wrangler for fuel economy. So the V6 seems to do well on trails now so why mess with something that works
