3.6 ticking
funnnyfarm
Al
Spokane Washington
2012 Rubicon 2 door
funnnyfarm
I have a 2014 wrangler with a 3.6 engine. It is starting to make the lifter or rocker arm ticking. I see that Jasper Engines has a up date on the rocker arm and floating roller in it. Did Chrysler up date that in the newer wranglers? Thanks
1BadManVan
Darren
Bc Canada
2019 Wrangler JLU Sahara/2018 Durango R/T
Locomotive Engineer
yes the 3.6 in the new JL is the Pug motor that was a complete redo internally. They addressed most of the weak points from the other gen motor
funnnyfarm
Al
Spokane Washington
2012 Rubicon 2 door
Did they ever come out with a up date for the 3.6 that had the rocker and lifter problem? I go to Chrysler and all they want to do is sale a new Jeep or overhaul the engine with the same bad parts. But that’s there job. Thanks for the info. Have a great day. funnnyfarm
DaltonGang
Doesn't Play Well With Others
Mine has a little ticking, which tells me it is about time for an oil change.
azjl#3
North AZ
might try some lucas oil modifier for low viscosity oil. Solves the low viscosity ticking at startup.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
Replace with a Jasper engine will cost you about 8-10k depending on location and labor costs unless youre doing the work yourself or have a good buddy hookup.
Best to just fix that motor if it’s just ticking.
azjl#3
North AZ
For $10 per oil change, it does help with startup ticking for sure. Warmed up ticking is a whole different issue.
