25 psi on 35" BFG KO2s load range E
Desert rat
Larry
Arizona
2013 wrangler rubicon unlimited
I have a 2013 wrangler rubicon unlimited with a 3.5 AEV lift. I like the handling with 25 psi. Is that too low for highway driving? Will it cause excess tread wear?
Tr4ckD4ys
NY
2025 Jeep Wrangler Rubicon Xtreme 35-inch 2-door, '41 Green
Tech
Hmm… it’s a little on the lower end. I’d say 30 is safer!
ScotM
Scot
Southern California
2022 Jeep Willy's JL 2 Door
You are definitely gripping the road at 25. But a chalk test would confirm that. On my 35s , 30 was the perfect pressure
azwjowner
Phoenix
25 is absolutely safe for the tires. As I've pointed out many times, a 35" x 12.5" tire is rated to carry 1875 pounds per tire at 25 PSI. Your Jeep weighs much less than 1875*4 or 7500 pounds.
How low tire pressure affects handling is a more complex question. It can make sharp turns less crisp, or affect how load shifts from side to side in sudden maneuvers. We really can't give you guidance there.
ArmyW4
Tom
Big Bear, Ca
2021 Rubicon, 2025 Nissan Z Spec Performance
I did the chalk test several times and ended up at 26 psi. Never had an issue.
Jmos4
Jim
2020 Challenger Scat Pack M6/2007 Ram 2500 G56
Hi,
I run that on my 35 12.50's Trxus MT. Only issues I have experienced is I do get a vibration at highway speeds that comes and goes, believe it's the sidewalls flexing and developing a harmonic.
I am running balancing beads in them so may not have the correct weight in them due to some blowing out seating the rim.
Regards,
Jim
mjbenedict
2018 Wrangler JL Rubicon 2 door
Calculations put my Goodyear Wrangler Duratrac E-rated 35s at 30psi and they ride great on highway at that pressure. Off-road they are bone rattling at 30psi.
TikiRick
Rick
North Jersey
2021 3.6 6spd JKU Islander
I've run several sets of 305/65-17 BFG KO2's @ 28psi on my JKU's...usually replace them around 60k miles. Currently running 28psi on 305/70-17 KO3's on my JLU, and so far, so good. Off road (beach or trail) I drop them to 18psi, and they do great....
