23' Wrangler 4xe P0B24 code
Oleg
Oleg
Lincoln, CA
4xe
I got today Service charging system" after 98% charging. OBD scanner showed error P0B24.
mabaker002
2021 Wrangler 4xe Rubicon
Takes a minimum of a week for STAR to approve and order the battery, and the battery can take up to 3 weeks to arrive. Do not expect your vehicle back for at least a month. Stellantis should provide you with a rental, give jeep cares a call.
Yep, took just under a month to get it back. but then after about 25 miles just before getting to work, the engine light popped on with code P2E46. ended up having to replace the coolant pump. but they got me a loaner and got it back to me in a couple days.
alphawolff
california
2021 JLU
P2E46 indicates they didn't properly bleed the cooling system. I'd say 90% of technicians don't know the actual bleed process after replacing the battery pack. Most will fill it up and run the coolant bleed procedure and think it's good to go, but you need to pressurize the system and run it *multiple* times. I doubt the pump actually needed replacing, even if it did run dry. These things love air pockets.
Bowevil
Michael
OBX
2021 Jeep Wrangler Unlimited 4xe
Bringing this to the top. I have the same situation as the person in this post: Reddit . I have ordered an ODB2 device and cable. Hopefully a reset/clear will resolve my issue.
