21' JLU Willys Wheeler vs JLU Rubicon axle width question
L06An_5
NJ
1999 TJ Sahara; 2019 JL Rubicon; 2021 JLU Willys Wheeler
Hoping someone can help me with this.
I am looking into replacing the stock Dana 30 front axle with a Dana 44. I know that the Willys Wheeler comes with the Dana 44 LSD rear. The question is, is the axle width the same as the Rubicon, which I believe is 67.9" or does the Willys have a 66.4" (Sport, Sahara) axle width even though it comes with the Heavy Duty Dana 44? I am assuming the width matters and I need a front axle with the same width, & gearing, as the rear.
Any help is appreciated.
My Build sheet only says:
- Dana M186 Front Axle
- 3.45 Overall Top Gear Ratio
- Dana M220 Rear Axle
- Anti-Spin Differential Rear Axle
- Conventional Differential Frt Axle
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
Willys has the narrower axle. Your Jeep won’t care if you put the wider axle in. You could also get a D44 front axle from a diesel model. It won’t have the locker though and will have 3.73s.
The best deal is to get both axles. Everything is there and then you will have 4.10s front and rear. By the time you regear the existing rear axle the cost won’t be much different.
L06An_5
L06An_5
NJ
Thanks for the quick reply..
JINO
Jino
Socal
2021 jlurd
Sorry for resurrection.
Is the 2024 willys front axle the same as the 392?
My buddy says the 4x4 shop told him this information.
Also, how does the diesel (rubicon) axle differ? Or is the same as gas rubicon?
Zeddy
Shawn
Vancouver BC Canada
2018 JL Sahara
I’m in the same position. I have a 18 JLUS, It has the 30/35 conventional 3:45 ratio. I’m currently on Rubicon take offs and a 2” lift. I would like to run 37’s. I was looking at a set of Dana 44 off a JTRD. From what I undertstand the mounts are different and I’d have to run 4xe control arms or something like that? Can anyone confirm.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Front should be the same. Rear will be the issue, to my knowledge the rear JT suspension is significantly different than the JL.
Zeddy
Shawn
Vancouver BC Canada
2018 JL Sahara
YES Sorry only the rear will be an issue. I heard they use the same mounting as the 4xe so you could use the suspension links from one of those but I wanted to confirm as it will make it messy while trying to buy a new lift kit? I guess I’d busy one for an 4xe and swap the axles in at the same time.
I’m just trying to find some cheap Dana 44 take offs but with all the options ands widths I’m trying to ensure I have the same width from front to rear.
GATORB8
CLT NC
Negative. The axle/housing tubes of the 4xe utilized the JT setup, but the 4xe has the JL suspension setup, not the JT setup.
