21 JL Death wabble
Steveb05
West Lafayette IN.
2021 LJ Sport
I have a 2021 JL 2 door with 35,000 miles and I experienced death wobble today while driving on the interstate after i hit a bump. Is this an indication that its time for some front end work. If so where do I start
andy29847
Andy
Trenton, SC
2020 JLUR
I have a 2121 JL 2 door with 35,000 miles and I experienced death wobble today while driving on the interstate after i hit a bump. Is this an indication that its time for some front end work. If so where do I start
Death Wobble is when it shakes so bad that it is tearing up parts and the shake will NOT stop unless you completely stop the Jeep.
How bad is you shake/wobble?
What speed does the wobble start?
Are your tires and wheels stock? What kind of tires and how old? Is the wear pattern on the tires similar and even?
Is your Jeep lifted? if so, what lift and how high?
Do you off-road your Jeep? have you been in any mud lately?
The first thing I would do is take a good look at my front tires and wheels. Is there any mud build up on the inside of the rims? Do you still see the weights that were used to balance the tires? Are the lug nuts tight? Have you had any of the wheels off lately?
Normally, 35,000 miles is too soon to have front end trouble. As you can read in my note, focus on the wheels and tires first.
onepoundjeepjl
Robert
youtube.com
2023 Jeep Wrangler Sport, White
Engineer
my wifes jlu got a minor vibration/wobble if you hit a bump going like 70+. had to slow down below 60 to get it to stop. her jeep only had 20k miles on it. stock everything sport s.
I dont think we really solved it but had all 4 shocks and steering stabilizer replaced under warranty. I say didnt really solve it cuz no one believes what we had done was the correct fix, but I couldnt see anything else wrong, and well there is no more wobble for now.
I think there is a lot of different crap that can cause it tho and no one has the perfect answer cuz theres so many possibilities. just gotta start looking for things wrong.
Opus
Midwest US
www.jlwranglerforums.com
I have a 2121 JL 2 door...
I would have bet Jeeps wouldn't still be around then... or humanity, frankly, the way we're going...
Megawatt
Sin City aka Vegas
money pits: Turbo Busa, Street Bob, 22JLUR snazz, 5.0 mustang MT
Powerplant operator
Get someone behind the wheel in the driveway or parking lot. Have them turn steering wheel back and forth (slowly) while you look at connections on tie rod and the drag link. If you notice slack or slop in the connections before the wheels start to move then it’s time for new bars.
It can also be as simple as needing to retorque the nuts on these bar ends. I have aftermarket so my torque values are different than you stock ones so I can’t tell you the value to check for.
Search torque values on this forum, there is an excellent thread/list of stock torque values.
I just changed all this on my 2022 with 40k miles last month.
Check YouTube for easy ball joint check video.
Jeep Wrangler JL 21 JL Death wabble IMG_1707
Steveb05
West Lafayette IN.
2021 LJ Sport
I was running around 70 when it started, Was able to slow down to around 60 to get it to stop. The jeep is bone stock with no mods. I Did have a flat tire on the Left front 2 weeks ago so i decided to leave the spare on the left front and delegate the Left front to the spare Tire carrier.
tk1700
Tom
New Mexico
2021 JLUR, 2016 Tundra, 2025 Hyundai Palisade
If it didn't happen before changing the LF tire, I would switch the tires back to how it was and see if it goes away.
andy29847
Andy
Trenton, SC
2020 JLUR
The spare is probably not balanced.
Ralphee
Joliet Illinois
2021 Jeep Wrangler JL 2 dr Freedom
I have a similar thing; a 2021 JL 2DR with 34,000 had the steering wobble violently as I was getting on an expressway and hit a bump. Slowing down to about 25 briefly got it under control. I checked tire pressure and noticed dealer had filled them to 36 pounds (recommended). I reduced the pressure to 32 pounds (which I prefer for more natural steering anyway) and haven’t had a problem in the last 1500 miles.
yokramer
Snark Incarnate
Its going to be ball joints or steering joints wearing out causing this. It isnt going to be tires, steering stabilizer, wheel balance or anything like that.
AskBin
22' Willys EcoDiesel
all things being stock, death wobble comes from worn out/loose steering components, an underdampened steering stabalizer, or an overall garbage design in the front end. i dont see how all 4 shocks would have solved it but glad you managed to get new ones under warrenty.
Ford had to redesign the stabalizer on their 250/350s to get them to stop wobbling.
every vehicle that i came across with deathwobble, you diagnose if theres slop in the box, tie rod, balljoints whatever can have slop in the steering system. then check to see if the dampener is blown out. if none of the above you need a larger steering dampener.
its a steering geomerty issue and dodge isnt perticularly known for their engineering prowess, but its also not some mystery issue that cant really be solved...
Nardulli
St Louis
2021 JLU Rubicon Diesel
My 2021 JLUR would start to wobble at speeds over 30 MPH if I hit a bump or pothole. It only has 15,000 miles on it. 2" MOPAR lift, 35's x 11.5 x 17. New steelies properly balanced. I put on a Fox through shaft type steering damper and the problem has not recurred. There's no slop anywhere in the front end.
Jeep Wrangler JL 21 JL Death wabble fox
onepoundjeepjl
Robert
youtube.com
Engineer
steering stabilizer was changed too, that was dealers fix.
I looked for anything else i could but couldnt see anything. I just know people say that replacing the steering stablizer is jeeps baindaid fix. I just couldnt see anything else wrong. it could be like you said thst the dampener was blown out (i didnt look at it before dealer replaced it), and so maybe for me that was the real fix.
