2024 Willy's Suspension Question
Loup Garou
New Orleans
Honda Odyssey Kia Sorento
All, new member here. I'm about 95 percent certain I'm going to order a 2024 Willy's as it includes any and all upgrades I would make to a Sport S...I do have a question about the "Willy's Suspension," however. What is it? Is it the same springs and shocks as the Rubicon? Something in between the Rubicon and Sport? What amount of lift if any over the sport does it provide?
Thanks in advance for all the help.
-Loup Garou
Loup Garou
New Orleans
Thanks! I definitely have, it's a great resource.
Riotfunk
Ma
22 Willys with 2 Doors
Is just same shocks and springs as Rubi plus beefier tires and the Rubi rails.
Loup Garou
New Orleans
Gotcha, so it is the same ride height as the Rubicon, correct? Thanks for the clarification...
SBLACK502
Charlestown, IN
2021 Jeep Wrangler
The rubicon typically sit higher than the Willy’s unless you get the recon package. This is why you see so many stock rubicon’s with 35’s and no lift.
Loup Garou
New Orleans
So I guess we've settled on a slight lift over a Sport, but not "all the way up" to Rubicon level?
My understanding is that the 2024 Willy's suspension is different than the previous JL Willy's model years....is that safe to say? I know the 24 model year gets the high rise fenders and 33s, so I'm assuming the suspension is different as well. Please correct me if I'm wrong.
Aturking
Andrew
Avon,OH
2023 Wrangler Unlimited Willys
The 2024 Willys gets the rubicon springs, high line fenders, m220 Dana 44 narrow track rear axle with e-locker and 285/70/17 bfgoodrich all terrains. The previous Willy’s have sport springs and fenders with rubicon shocks, m220 narrow rear axle with limited slip, and Firestone desrination mt in 255/75/17. Lots of differences in the 24.
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
2024+ Willys will have the same suspension that regular Rubicons have. So they will have the same stance as a base Rubicon. Maybe there are some slight differences for 2024 Rubicins, but a 2024 Willys will sit the same as a non XR Rubicon did from 2018-2023.
KevinBoston
Kevin
Boston, ma
2024 Jeep Wrangler
2024 Willys - The ground clearance is 10.8 inches. I believe this is the same as the base Rubicon. The dealer told me that they both sit the same with the same 33-inch tires and the same Heavy Duty axles. The big difference is the Rubicon has the front locker and disconnects.
I believe the 2023 Willys had 9.7 Inches. (Someone can verify 2023 Willys))
Fatbob Frank
Frank
N.E. Iowa
2024 Wrangler Willys
Lab Tech
FWIW mine came with 285/75/17 Falken Wildpeaks, not BFGs which I'm OK with...
Jeep Wrangler JL 2024 Willy's Suspension Question willys2
ASSFROW
Gary
Mt. Airy, MD
2024 Rubi X
The 2024 Rubicon has a Full Float rear axle. The Willys does not.
ASSFROW
Gary
Mt. Airy, MD
2024 Rubi X
The 2024 Willys have the M210 Wide HD Tube front axle and M220 Wide Rear axle. The 2024s have the wide axles. The 2024 Willys is a great deal for what you get.
Notgeowild
Geo
Dallas, TX
2024 JLUR XR
As for the height between willy's and rubicon I see them by the hundreds on our lot. I dont think it's higher than the Rubicon. I might be just used to seeing them all together I see no difference almost. lol
