2024 vs 2023 Suspension
SmokeyJoe101
Gerald
MS
24 Sahara
Retired Combat Vet
  • Thread starter
  • Banned
  • #1
I am looking to lift my Jeep and am noticing most lifts are spec for 18-23 model JL’s (non-Rubicon, if that matters) and specifically state non-2024 models in some cases. Is there something different between a 24 and 23 suspension wise?
MeefZah
Lexington, Ohio
2020 GX460
I'm seeing the same thing in my searching for products, but everything underneath both model years (model compared to same model) appears to be the same. I assume most aftermarket mfgs just haven't confirmed fitment or updated their websites.
SmokeyJoe101
SmokeyJoe101
Gerald
MS
24 Sahara
Retired Combat Vet
  • Thread starter
  • Banned
  • #3
That was my thought as well, except some manufacturers are specifically saying not for a 2024. Which means they have updated. I reached out to few, but have not heard back from any yet
Fabtech Motorsports
Peak Sponsor (Level 2)
CA
Jeeps, trucks, Broncos
FYI on this, we have found that there IS a change from 23 to 24 models. What we found was minor but needs to be addressed. That change? Front sway bar end links. More specifically... the bushings used. LOL
We have (in the process) of extending out coverage to 2024 for JL/JT's.
Fatfreewilly
Bubba
PA/NJ
2016 JK Black Bear Edition - 2dr.
Bolt size/heads are different too. Needed a few trips to the store when I tired to do a swaybar disconnect install on a 2024.
Fabtech Motorsports
CA
Yes!
Thanks for adding that info.
In my mind it's a "parts pack" , a bunch a nuts/bolts/etc. LOL
Bill007123
Bill
RI
2024 Rubicon X, 2 door MT.
I just installed the Mopar lift on my 2024 and yes the ONLY difference was the front sway bar link bolts changed from 12 mm to 14 mm. The kit actually included the new bolts but I had to order bushings from Metalcloak.
TXSquid78
2024 Willys 4xe; 2005 Corvette
Does the 24 Willys lean towards the Rubicon lift kit or the non-Rubi lifts? The 24 Willys is near identicial to the Rubicon but the 23 I believe is equivilent to the Sport suspension.
