2024 Grab Handles
NXTGENAutomotive
Peak Sponsor (Level 2)
Carlsbad, CA
25 Rubicon XR
I found the link to ebay.ca but for some reason eBay says the item doesn't fit
I'm assuming that's just eBay who hasn't updated their fitting system yet?
I have a JEEP JL 2024 SAHARA (GAS only engine)
also dumb question, but if I order (2) quantity, this will give me a set of all four grab handles correct? which will fit front and rear
Thank you!
We will need to look into why eBay says that. Thanks for the heads up!
Yes, will absolutely fit a 2024.
Correct, each set is a box of 2 so you can do front or front and back with 2 sets. These will fit the front and rear points.
✌- The NXTGEN Team
jonboy
Jon
NorCal
2021 JLR (stock), 2012 JKUR (one tons on 39s)
Quick question for those with the GPCA Air grab handles - can you remove the fabric from the center metal hoop? It looks like the part you grab comes off easily enough as it looks like velcro, but unclear on the part that mounts to the rollbar. I'm wanting to powdercoat these to match my '41 color, hence the question. None of their color options will work well enough unfortunately.
Fourthandlong5
Pottstown, PA
2025 Wrangler Willys
Yes the Velcro wrap comes right off the handle. I had the same idea and picked up a can of Mopar color match paint in Anvil and painted the handles before installing. And for the grip part I’m NOT going to reinstall the Velcro/vinyl wrap and instead use some LizardSkin grip tape (used on baseball bats) instead.
virkdoc
Ramandeep
Chandigarh, India
Cayenne V8, BMW 330i, BMW R1200GSA, Jeep Rubicon 2022
Fourthandlong5
Pottstown, PA
here are the GPCA handles with the standard Velcro/vinyl wrap removed and replaced with the LizardSkin baseball bat grip tape. Much better !!!
Jeep Wrangler JL 2024 Grab Handles IMG_7825
