2024 Dash Style Retrofit - Android head unit
DC3
Summit Sponsor (Level 3)
Carl
MN
dilabs.cc
'21 JT EcoDiesel, 22 Polestar
Engineer
I started this post on the Gladiator forum and figured I would x-post for the benefit of the Wrangler owners.
I am not affiliated with the Aliexpress seller or HU manufacturer, just a guy who upgrades and shares. The content is spliced from a few different forum posts.
I've casually been researching the feasibility of retrofitting the 2024 dash but haven't had the time to pull everything together. The primary purpose is the new head unit; I don't particularly like that the factory head unit runs the Uconnect OS. I'd much rather have Android, where I can use apps natively without a magic box (android plugin).
I have been running the Stinger HU with a magic box for Android and 4G internet. Unfortunately, the system doesn't allow for multitouch, which is a PIA in map apps.
This new Android head unit has been the best option I've found. It's only been one week, but I will share my findings.
For context, I originally had the Uconnect 8.4", Insane Audio JL3001, and most recently the Stinger Heigh 10. I had been running a magic box (android unit) on the Uconnect and Stinger units.
I have the factory auxiliary buttons, front and rear cameras, and all other options except locking diffs. The vehicle settings menu "was" important; more on that later. I have the MB Quart speakers & amps, along with a Kicker-powered sub.
My primary purpose in moving from the factory unit was to have Google Maps, streaming music, and other Android apps. I don't connect my phone to the head unit because the Android Auto is watered down and takes over phone calls where I prefer to use my earbuds. The magic box was a great solution, but the limitations included poor cold weather performance (it wouldn't run in subzero temps) and didn't have multitouch (an issue with how the magic boxes connect to head units).
The new Android head unit:
Specs:
  • 12.3" 1920x720 screen
  • Android 12
  • 6GB Ram
  • 128GB Rom
  • UIS 7862 Octacore CPU 2Ghz
  • CANBUS box for HVAC integration
  • 4G Connectivity
Pros:
  • Fast boot
  • Zippy performance
  • Firmware and System settings are customizable
  • Looks amazing + beautiful screen
  • Horizontal is the best screen orientation for the Jeep, they got the 2024 dash design right
  • center vents are a perfect match
  • DSP system with full equalizer
  • Great sound output
Cons:
  • I ordered the 8GB Ram + 256GB Rom but this must not be available
  • Factory menu is not available (I thought this would be a show stopper but it isn't)
  • The backup camera doesn't work yet (it shows no signal, but I have a solution)
  • The kit replaces the trim for the gauges and the design is like the 2024 gauge trim, which is flat vs rounded. The Chinese version isn't ergonomically correct, it seems designed for more of a straight-on view (perhaps for a person with a shorter torso)
    • I am going to try to make my factory gauge trim work
  • There are no instructions
  • The unit partially blocks the left passenger vent
I'll add updates as I experience new things. In my opinion, this is the best aftermarket head unit for the 2018 - 2023 JL & JT platforms. It's also a great way to get the 2024 dash design without the $2k - $4k investment.
Jeep Wrangler JL 2024 Dash Style Retrofit - Android head unit 2023-11-18 09.18.13
Jeep Wrangler JL 2024 Dash Style Retrofit - Android head unit 2023-11-18 09.18.03
Jeep Wrangler JL 2024 Dash Style Retrofit - Android head unit 2023-11-18 09.17.51
Jeep Wrangler JL 2024 Dash Style Retrofit - Android head unit 2023-11-18 09.17.42
Jeep Wrangler JL 2024 Dash Style Retrofit - Android head unit 2023-11-18 09.17.39
Jeep Wrangler JL 2024 Dash Style Retrofit - Android head unit 2023-11-18 09.17.28
DSMJL
Alex
IOWA
2018 JL
Have you been able to figure out the backup camera yet?
DC3
DC3
Carl
MN
dilabs.cc
Engineer
Yes! The backup camera is working. I needed a digital-to-analog converter box which is a pretty common component. It should have come with the radio, they ended up shipping it separately.
I have the factory front offroad camera and I haven't figured out how to switch to that camera, I suspect I will need an app similar to whats on the Insane Audio system.
I am still happy with the setup.
IanNubbit
Ian
NJ
2022 JT 6MT Sport & 2023 JL 2 Door 6MT Sport
Jeep Dealer Tech
What's the plan with that passenger center vent? Can only see that being detrimental to the screen when the heat is on.
DC3
DC3
Carl
MN
dilabs.cc
Engineer
I'm not worried about the passenger vent, it isn't directed at the screen. The driver vent runs along the back which will also generate some heat but that won't impact the headunit IMHO. I think there is far more concern from heat due to an open top and direct sunlight.
Smart252
Steven
Los Angeles
Wrangler JLU
Thank you for the detailed write up! Any new issues that have come up? I know these Android units are a hit or miss, but this one looks/fits great!
bugnuker
Shane
Arizona
1969 Buick Skylark
Why? All this work so you can run any android app instead of the approved android auto apps?
What benefits does this give that the 2024 system does not?
Can't you simply side load using a rooted phone?
Just seems like a ton of work to rip apart everything just to run some apps that you probably shouldn't be.
I will say, I want weather radar apps, like Windy, and this would solve that, but holy cow, I'm not going through all this just to get windy on my android auto!
OminousSkitter
The Ether
Trek Bicycle
Because replacing the headunit is cheaper than buying an entire new car for those of us who have a JL 2018-2023? I don't keep up with it, but last I read no one had an OEM UConnect5 headunit working on a Uconnect3/4 Jeep.
bugnuker
Shane
Arizona
1969 Buick Skylark
I totally understand upgrading pre 2024. But he upgraded a 2024... He ripped apart the dash and removed the large screen that the 2024 introduced and put this thing in there. Why?
OminousSkitter
The Ether
Trek Bicycle
You're talking about OP (DC3)? He didn't. He upgraded a 21JT that previously had the 8.4, InsaneAudio 3001, and Stinger Heigh10 (none of which are compatible with a 2024).
Patrick
Queens N.Y.
Subaru Ascent.
Specs:
  • Android 12
  • 6GB Ram
  • 128GB Rom
  • 4G Connectivity
Pros:
  • Fast boot
  • Zippy performance
Cons:
can you use Gaia on onx with this head unit?
