2024 accessory gauges gone, except for voltage?
IdowaJeeper
Travis
Eastside of Washington state.
2024 Wrangler UL Sport S 4XE, 2024 Ram 2500 Crew Cab Cummins on 35s, Kodiak ATV.
I was scrolling through my menu and wanted to check on the engine temp and all I have is the voltmeter..
Jeep Wrangler JL 2024 accessory gauges gone, except for voltage? 20241027_161752
It's a pretty intuitive screen and I messed around with it for a bit and couldn't figure it out. Tried reset, tried shutting off the vehicle and restarting. Nothing so far.
Any ideas?
Fatfreewilly
Bubba
PA/NJ
2016 JK Black Bear Edition - 2dr.
Other than holding the power button down until it does a soft reset... I got nothing.
I'd check with the dealer.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Any ideas?
Did it return to normal today?
IdowaJeeper
IdowaJeeper
Travis
Nope. I tried resetting it and returning to factory settings. Nothing.
All I've done was install the winch and disconnect a ground wire on the battery momentarily while the winch ground was added.
Not sure how to restart the Uconnect 5 system to see if that helps. EDIT: looked it up and will go try that.
Dlit
South Florida
Rubicon JL Recon
It has been stated on the forum that it can take a few days after a reset or software update. Park it where it has a good signal an hope big brother does its thing…….good luck.
