silverwing
Does the ‘21 Wrangler give you a warning when you when you need to change your oil?Or does it just show the percent?
I believe it's when you have either 5 or 10% left on the indicator that it will also start showing a warning as mentioned.Does the ‘21 Wrangler give you a warning when you when you need to change your oil?Or does it just show the percent?
